So, the title basically says it all.
The videos Im trying to convert are around 180 MB and the projected file size are 700+ MB.
Im trying to convert the avis to vcd-compliant mpgs.
The videos are all interlaced and were encoded with the XVID codec.
Any help is appreciated.
What's the problem?
VCD mpg is ~10 MB/minute.
A std CD-R can hold close to 800 MB mpg when authored as VCD.
AVI file size is irrelevant.
/Mats -
I think I need to elaborate more on my problem.
I have 3 avi files, each are about 180MB. Im trying to burn all three into one vcd.
Ive done this before with videos of the same file size and theyre always projected to come out at about 240+ MB each. -
Again: Source file size is irrelevant when it comes to encoding them for VCD. The only parameter to look at is time. A VCD can hold 80 minutes. And it doesn't matter if the source file is a DV video of 16 GB, or a low bitrate DivX at 500 MB.
/Mats -
So, what youre saying is if the combined file size of the 3 mpgs exceed 2 gigabytes, I can still burn them all on one cd-r as a vcd?
Each avi is around 23 minutes. -
No, I'm saying that if the combined play time of your source files is less than 80 minutes, they can be encoded as VCD mpg and authored as VCD.Originally Posted by Timex
If you have 3 AVIs of 23 minutes each, they can be encoded to VCD mpg and authored to one disk. When encoded using the VCD specs, they should come out at 230 MB each.Originally Posted by Timex
/Mats -
What he's saying is: video correctly converted to VCD MPEG1 has a fixed bitrate where 80 minutes will fit on one CD. If your 69 minutes of video is coming out at 2 GB something went wrong with the conversion.
In all likelyhood your sources have variable bitrate audio which usually confuses TMPGEnc. You should use a program like Audacity to extract the audio tracks and save them as uncompressed WAV. Then import those WAV files into TMPGEnc.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 23:34 -
MeGUI: Problem calculating AVI file size
By fakecake in forum Newbie / General discussionsReplies: 9Last Post: 1st Feb 2009, 09:11 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
AVI File Size problem
By prcole18 in forum Capturing and VCRReplies: 5Last Post: 14th Jul 2008, 19:05
