I tryed to play LOTR-SVCD(Tcf-release) on my newly bought Pioneer DV-444. The image unregulary freezes for like an half of a second and then continues. That doesn't make the movie very fun to watch.
Tryed with an other movie, "Enemy at the Gates" with the same result.
What's wrong ? Could it be my CD-burner ?
Results 1 to 11 of 11
[I have a similar problem with SVCD I made myself. So, it can't be you burner. I tried other SVCD bitrates without results. Did you try the SVCD with other players ?
I haven't yet but that will be the next thing I'll do in the search for proper SVCD-playback
It looks like you have to make your SVCD's with TMPGEnc, load the SVCD template and burn the SVCD's with VCDeasy. Don't use Nero.
The DV-444 despite all that you might read DOES NOT play SVCD's
my friend has one - it doesn't play them ... sorry have to tell you that
if you just bought it get a 343 ---- it's not as 'pretty' looking but it blows away the 444
I know the LOTR SVCD's you are talking about - they played flawlessly on my 343your pal,
Stinky -
Thank you Stinky. I shall yell at my retailer as soon as possible and check out your story. If your story checks out, I will no longer own a 444 :)
why shouldn't I use Nero ? Why will VCDeasy be any better ? I have a quite old burner too so it will probably not be supported by VCDeasy.
he he --- you will be much happier with a DV-343Originally Posted by nill
the 444 LOOKS GREAT - it just isn't good for someone who wants to be into VCD/SVCD's ... an it choaks on xVCD's and xSVCD's also!
I swear I just went through this the other day with a friend of mine - we tested everything and it played very little.
I think the 343 is going for 139.00 or so via the internet. I have 3 of them in my house :-)your pal,
Stinky -
I am just wondering if the DV-444 can't take the high bitrate....according to biterateviewer LOTR has a peak of 2887Kbps which seams a little high...but hey I haven't tried the DV-444 myself so I don't really know....
I brought over a ton of disks to my friends house (he had just purchased a DV-444) it didn't play any SVCD or xSVCD correctly -- I think it played one of the xSVCD's *kind of* but it stuttered a lot
I would not recommend a DV-444 for anyone who is going to make VCD's or SVCD's or any bitrateyour pal,
Stinky
Newb Help Please - LOTR Extended Edition
By dpend in forum Blu-ray RippingReplies: 7Last Post: 5th Jul 2011, 13:21 -
LOTR extended editions hits bluray - you buying?
By yoda313 in forum Off topicReplies: 1Last Post: 20th Apr 2011, 08:14 -
Born of Hope - LOTR fan film
By freebird73717 in forum Off topicReplies: 0Last Post: 23rd Jan 2010, 15:19 -
LOTR Bluray preorder now available - theatrical release only for now
By yoda313 in forum Off topicReplies: 3Last Post: 16th Jul 2009, 18:52 -
Multiple DVDs one file(LOTR EEs to be exact)
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 23:39
