  1. Hello long time last post but i have a problem i have put a eposode dvd (4 eposods ) in VIDEO TS form on a backup disc but have managed to put them in the wrong sequence is there any way to edit them so i can get them back in sequence as the original disc is now unreadible (scratched)
    Aug 2004
    Easiest way it to re-author. Demux and separate by pgc using pgcdemux. Then author the sequence you want it.
    You can also use pgcedit to re-do the sequence but it may be way over your head.
