i am using VirtualDub to join two videos together but i get this error message:
Shot
any help please?
Results 1 to 11 of 11
It looks like you have VBR Audio in your files.
You need to re-compress the Audio first for each of the files with CBR MP3 & then join them. -
You might try dropping them in Gspot 2.70 as it will tell you if they are VBR. I use VirtualDub Mod most of the time and it will immediately let you know if you have VBR.
The two files have to be exactly the same to join them with VD or VDM. If you are joining them to convert to DVD afterwards, I wouldn't. It's better to encode them to MPEG-2 separately and let your authoring program 'join' them. A lot less chance of sync problems that way.
But if you do need them joined, you will have to change one or the other so they match. Or you might try AVIDeMux and it may be able to join them as they are.
BTW, for VBR audio using VDM, I use extract out the audio as a WAV using full audio processing, then add it back in. If you want to keep the Xvid format, re-encode the audio to MP3 CBR and the video with Direct stream copy. -
The error message is telling you the audio sample rates are different. If you export as uncompressed WAV in VirtualDub you'll also need to use the Audio -> Conversion... function to change them both to the same sample rate.
Just about this AVI Demux.
Can it join 2 avi clips without re-compressing them, just like VirtualDub??
Thanks a lot. -
Yes.Originally Posted by navi310
CTRL+O opens first file
CTRL+ALT+A opens your second fileHe's a liar and a murderer, and I say that with all due respect. -
Thanks a lot, steveryan. Will definitely try that program because re-compressing VBR audio in VirtualDub sometimes gets annoying
i just ripped my music dvd by cell ID so the music videos come out separately using DVD Decrypter, then i converted them to XviD using AutoGK, the problem was the intro to one of the vids came out seperate to the rest of the vid, i just want to join them up again
Isn't it against SONY law to join two Michael Jackson videos. especially back - to -back ?
javascript:emoticon('
lol, nah, theres 2 parts of heal the world, like theres an intro of mj talking and then it cuts and then the song starts
How to join multiple youtube videos ?
By skorpinok in forum EditingReplies: 1Last Post: 13th Jul 2011, 23:42 -
append / join .mp4 videos
By blackrat in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 11:14 -
How can I join my H264 videos?
By Daninet in forum EditingReplies: 8Last Post: 17th Jun 2010, 16:44 -
How to join two videos in the same window?
By bgeorgalas in forum EditingReplies: 5Last Post: 23rd Jun 2009, 07:49 -
Need to join two videos and then convert
By vkosinets in forum EditingReplies: 1Last Post: 17th Feb 2008, 08:10
