Hello
I've done a bit of looking, and most of the info I've found deals with DVD to DVD conversion. I doubt it is much different going from DV, but just in case, I'll ask.
I'm currently using HCenc to encode my NTSC DV to NTSC MPEG2, and would like to be able to use the same tool to encode the same DV to PAL MPEG2. I know there are AviSynth filters that can change the framerate, but I understand the result isn't all that smooth. So I guess the real question is whether HCenc can handle that internally.
Failing that, I'm open to all suggestions. Thanks to all!!
oh the movie never ends...
Most PAL DVD players can handle a 480i NTSC DVD.
PAL conversion would be difficult and would require deinterlace thus lowering quality. Do you really need it in PAL? -
I'd like to send the DVD to family in Germany, Austria, and Switzerland. I don't think their TV's can handle NTSC the way they do in South America. (S. America get so much programming from the US that most TV's there handle NTSC as well as PAL).
I suppose the other option is to just send a NTSC DVD for playback on a PC.
Also, my copy of Nero OEM Suite that came bundled with my DVD burner will do the conversion, but I'm not sure about the quality.oh the movie never ends... -
Most PAL players play NTSC DVD to a psuedo PAL60 that most modern PAL sets will display. Send them a test DVD and see if they can play it. Conversion to PAL 25 fps is difficult.Originally Posted by towtruck
Sounds like the best solution. Thanks!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
