Hi all,
When I hardsub (using the VOBSub textsub filter) an .avi file with an .srt file using VirtualDub, I typically change my font size, text color, and outline parameters and this works just fine for a single job.
But when I run a batch job VirtualDub apparently doesn't retain these settings and hardsubs my .avi files using the default settings... Is there a way to force VirtualDub and/or VOBSub to use my subbing parameters all the time or at least during the batch run?
Any suggestions would be greatly appreciated.![]()
Frank Zappa: "People wouldn't know a good movie if it smacked 'em in the face."
How?
All you can set is the charset.
The way to go is to create ssa subs. Use aegisub.
You could also create style files.
Either using say subresynch from vobsub,
or creating the styles in aegisub, saving an ssa sub, opening the ssa file
and ripping the header to create a separate text file. so you have so:
sample.srt
sample.srt.style
create a few styles,
make a copy for each srt with required style, rename.
it's easier to just convert to ssa
gl
Hardsubbing MKVs
By Zepwich in forum SubtitleReplies: 5Last Post: 19th Aug 2011, 17:07 -
Problem hardsubbing Vobsub with Avisynth/VSFilter
By gklitt in forum Video ConversionReplies: 0Last Post: 1st Jul 2011, 17:43 -
hardsubbing xmediarecode
By fester77 in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2011, 10:49 -
Slight problem with GOM Player
By jonghyunchung in forum Software PlayingReplies: 1Last Post: 22nd Oct 2008, 03:04 -
Sub will not show on Hardsubbing
By arabian in forum SubtitleReplies: 0Last Post: 1st Jan 2008, 08:14
