i have had my mp3 player for a couple of months now but lately it keeps freezing as i turn it on. the screen stops and i don't even have a chance to start playing my songs. The only way i can turn it off is by taking the battery out. This happens several times then it plays normally. i have changed the battery but still no change. What else can i do? thanks
Moving you to our computer forum. DVD to AVI is not mp3 player related...
Take it back? If it's just a few months old, there must be some warranty left.
/Mats -
i don't want to take it back, i was just wondering whether it could be some sort of a corrupt file?
If it freezes as sooin as you start it, I doubt it's a file that is your problem (unless the player autstarts playing something). But I can well imagine a broken MP3 may cause a player to lock up.
/Mats -
It would be even nicer if you said what brand ... or some reference as to where it came from in order to determine the cause .
http://www.mympxplayer.org/portal.php , may be of help .
Lockups can come from :
Firmware issue = update
Wrong type of battery used .
Mp3s wrong frequency and / or bitrate
Actual fault with hardware = under warrantee , return it for repair / replace / refund
First thing would be to connect to pc and copy the tunes to a folder on the pc .
And remember what drive letter is associated with it in windows explorer ... important .
After , close windows explorer .
Now
Right click on my computer on desktop
Select "manage"
New window appears
Click on "disk management"
Remember the letter as shown in windows explorer ... thats the one you want
Its listed as removable
Where it says the actual drives letter (note the format)
Right click , and select format
Answer yes
Check it is set to correct format type , and click ok
Wait till completed
Close coputer management once done
Now put mp3's back on unit
Retest .
If it plays a default video on screen , it's possible the firmware needs updating in order to fix it . -
this is my mp3 player:
http://www.currys.co.uk/martprd/store/cur_page.jsp?BV_SessionID=@@@@1351405628.1182881...m=null&tm=null
go to this link and see my mp3 player.
how do i update the firmware?
MP3 Player
By slayer_of_all in forum Newbie / General discussionsReplies: 4Last Post: 20th Apr 2010, 09:53 -
Mp3 player dilemma
By alintatoc in forum Off topicReplies: 1Last Post: 10th Dec 2009, 17:11 -
Mp3 player?
By alintatoc in forum Off topicReplies: 4Last Post: 5th Jul 2009, 15:20 -
TEVION 8000 / 8001 HDMI DVD PLAYER problems with picture freezing....
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:56 -
Tevion 8001 HDMI DVD player - disc sticking/freezing problems.
By denny91 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Oct 2007, 09:50
