After installing SVCD2DVD 2.5.2718 DEMO it just once produced a DVD. I am using using 1 pass encoding. From the second try to do a DVD I get the message:
Version: SVCD2DVD 2.5 DEMO
Build: 2.5.2718.0
Type: System.IO.FileNotFoundException
Source: mscorlib
Message: Could not find file 'D:\Polar_S2D.mpg'.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileInfo.get_Length()
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
My log file is:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Name: SVCD2DVD 2.5 DEMO
Title: 2.5 DEMO
Version: 2.5.2718.0
Executable: D:\Programme\BadgerIT\SVCD2DVD v2.5 DEMO\%APPNAME%.EXE
Executable size: 2,37 MB
Executable size in bytes: 2486272
Executable CreationTime: 01.01.2000 00:00:00
Executable LastWriteTime: 01.01.2000 00:00:00
Executable LastAccessTime: 01.01.2000 00:00:00
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : D:\WINDOWS
OSLanguage: 1031
CodeSet: 1252
CountryCode: 49
Local: 0407
Total Physical Memory: 767 MB
Free Physical Memory: 548 MB
Total Virtual Memory: 1,99 GB
Free Virtual Memory: 1,95 GB
***************************** Computer *****************************
Computer Manufacturer Name: Fujitsu Siemens
Computer Model: GA-8STXCFS
System Type: X86-based PC
Computer Name: TEST-FRANO
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: TEST-FRANO\Frano
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz
Description: x86 Family 15 Model 2 Stepping 4
CPU Speed: 2,411GHz
CPU FSB: 133MHz
L2 Cache Size: 0 Byte
***************************** Time Zone ****************************
Time Zone:
****************************** VIDEO *******************************
Name: NVIDIA GeForce2 Ti (Microsoft Corporation)
Processor: GeForce2 Ti
Mode: 1280 x 1024 x 4294967296 Farben
Video Ram: 64,0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 2,12 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 781 MB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 2,57 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 2,09 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 29,3 GB
DeviceID: J:
FileSystem: NTFS
FreeSpace: 19,2 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="25.06.2007 15:36:50" Filename="NONE"><AssetSet><Asset ID="ed85d603-64a3-4e3e-819b-f90c23305180" Path="D:\" Filename="Polar.mpg" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="Polar.mpg" AssetID="ed85d603-64a3-4e3e-819b-f90c23305180" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="D:\Programme\BadgerIT\SVCD2DV D v2.5 DEMO\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="G:\" InitialProjectFolder="" InitialMenuBackgroundFolder="G:\" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="skip" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 209 MB
file=D:\\Polar.mpg
FormatName=mpeg
Num_Frames=16512
DurationInSecs=660
Duration=00:11:00.4
VideoCodec=mpeg2video
VideoFFSTNum=0
Width=480
Height=576
Standard=PAL
BitRate=2658
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1c0]
Audio1SampleRate=44100
Audio1Codec=mp2
Audio1BitRate=224
Audio1Channels=2
Processing Polar.mpg
Leaving source audio alone. (NOT IN DEMO)
15:36:50: Done: Processing assets for DVD creation
Authoring DVD Folders
I reinstalled Microsoft .NET Framework 3.0 (including 2.0) and SVCD2DVD 2.5.2718 DEMO, but I get the same alert. After closing the alert (3 times), the software quits with a Windows message.
What's to do?
Results 1 to 19 of 19
Franz Lambert
Drive space issue?
DeviceID: D:
FileSystem: NTFS
FreeSpace: 781 MBDwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thanks for quick answering.
I've found the culprit. It's not the drive space. For doing DVD's I'm currently using a drive with 23GB free.
As we all know, SVCD-audio-standard is MPEG-1 44.100 Hz. All my TV-records do have this audio format.
My first try with SVCD2DVD I did with standard options: AC3. This job was done. Then I changed options to leave audio as is. I didn't wont it to be re-encoded. With this option choosed I got the failure message. For me this is strange due the prog is made for burning SVCD on DVD without re-encoding. When I change to AC3 or MPEG all is running fine.
Meanwhile I'm working with SVCD2DVD 2.5.2728 DEMO. My questions:
1. Has the registered version the same "bug"?
2. With audio options MPEG the vob-file is 10% bigger than the mpeg. GSpot says, audio is 48.000 Hz. Is audio really re-encoded or just changed the header?Franz Lambert -
1) I would say "yes" as it is not a 'bug'.
2) Audio is really re-encoded to DVD standard, it needs to be for some players to recognize and play it. The video is not re-encoded, but during remuxing, I believe some code (navpacks?) may be inserted to allow better playback (such as the chapters you are adding).
Space can be an issue on the source drive because that is where the de/remuxing and audio encoding take place.
I would recommend always converting audio where SVCD (or VCD) is involved, you never know what your next player may (or may not) support.Dwight
- Herm Albright
It's surely well done to hold the compatibility wide open. Thanks in so far.
But for me it is a real bug, to let let me switch the options to "Keep source audio always" although a source file 44kHz lets the software quit with a common error message. It took me a while to find out the reason of the crash and shoudn't happen really.
Is there any other multiple condition for this crash? -
Keep source audio always does exactly what is says. If you post your whole log i will take a look.
My whole log is up here in my first post. The 'AV Details' are followed by the last 4 lines:
Between line 2 and 3 normally are many more lines. With "Keep source audio always" enabled the app crashes with the message in my first post and those lines are missing. Anything else? -
Nope. It is a bug. It is not in the registered version however.
Thanks for the heads-up. I have updated the download with a fixed version. Let me know if it now works ok for you.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Sorry, CrissyBoy. Didn't see your post. I will test tomorrow and give a feedback.
Ok. Thanks.
Ah, was a bug. The drive space and short log threw me - thought it was a de/remuxing & space issue. Glad you guys got it sorted.
Dwight
- Herm Albright
The update is ok. 'Keep source audio always' is working fine now.
I got more questions:
1. The preview is not working. All player buttons are greyed out. When I click on the movie button in the upper left of the preview window, I get an alert. Is this the same in the registered version? The alert is:
[/img]
2. The settings window can't be seen completely. It is truncated on the bottom. Is this the same in the registered version?
3. How exact is the filling meter preview (excuse my english) of the DVD? Does it show the source length of data or the final length after re-encoding - specially from 44kHz-audio to 48kHz? I'm used to fill my DVD's up to the top with a couple of movies, choosing from a big pool. Can I get the final length in numbers like in Nero?
1. The preview works fine in the registered version provided your system has the right codecs. Where are you trying to play the asset from? It needs to be in a VTS, then you need to click on the asset to enable playback.
2. The settings window can be cut off if your font settings are larger than normal. It used to be possible to click the window and maximize it, but this no longer seems to work (ChrissyBoy?). A work around is to lower the font size, make changes, and restore your font size.
3. My experience is that the estimation is very accurate and represents space used after any encoding (hence the 'autofit' button which is available with other than .mpg source files). Keep in mind that there are source files available that will not proccess predictably so some over/undersizing can occur from time to time. The oversizing is easily remedied with the use of DVDShrink.Dwight
- Herm Albright
Back to the preview error- can you play your source file in MPC? Are you clicking the VTS button ('New Movie" icon) under "Movies" or the source file icon under "VTS Layout"?
Dwight
- Herm Albright
If the asset plays in WMP it will play in S2D preview.
You can resize the settings window as required.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Chris,
I also seem to be unable to change the settings window (although it is sized properly for me), and I believe maxxjulie posted about this a couple days ago. If I right click, the minimize/maximize options are grayed out and I can't "grab" the edge to drag. Maybe I'm missing something? Using 2.5.2728.Dwight
- Herm Albright
Well build 2733 is on the site now (although it isn't anounced - as i have yet to compile a change list) and i think that is what RainbowLand is using as he redownloaded.... And the settings form is now resizable:
Cool, I'll grab that one - thanks.
Dwight
- Herm Albright
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Cannot Find Operation System discs for Any of the Computers
By kerrex_2006 in forum Newbie / General discussionsReplies: 9Last Post: 10th Jan 2008, 13:47 -
System.IO.FileNotFoundException problem
By bestbuyer_2004 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 24th Jul 2007, 12:49 -
By captaincaveman in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jun 2007, 12:55 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
