Hello all,
This is my first post to the forum, so please excuse any blunders I may make!
I have an issue with edge artifacts/noise being caused by transitions when exporting an .avi from both Premiere Cs2 and Cs3. (And viewing the exported clip in Virtualdub or similiar programs.) If I disable the transition, then the noise disappears in the exported .avi. I have tried to use an additive dissolve, cross dissolve, as well as simply adjusting the clip opacity to duplicate a dissolve, but every method I have tried has produced the edge noise/artifacts.
The settings for the project are as follows:
Editing mode: Desktop (standard settings)
Video Rendering:
File format: Video for Windows
Compressor: Huffyyuv v2.1. ("YUV Renderer Fix")
I usually further export the movie as a "Huffyyuv v2.1" movie. (Using the "YUV Renderer Fix" compressor, which I believe is the same as the "Huffyyuv v2.1" Also, I have the project settings set for RGB (RGB compression method: Predict Gradient (Best)), as well as exporting as RGB as opposed to YUV. (Since exported YUV clips tend to crash my VirtualDub, which is an annoyance...)
Incidentally, I had tried everything I could attempt/research to track down the cause of the issue, and I finally disable the transitions, which caused the issue to disappear. So I am pretty sure this issue is related to the transitions. (It took me a week to figure this out, which is a bit fustrating!)
Any help would be much appreciated, and I can provide futher assistance if required.
Thanks in advance!
Baculus
Try exporting with transitions as uncompressed RGB. If you still have artifacts the problem is in Premiere.
Ok, thanks for the reply. I had thought about doing that, but the uncompressed files are so huge, I didn't think that VirtualDub would be able to compress the files to an Internet-friendly size. But I will go ahead and try that as well.
Thanks again. -
but surely huffyuv is a lossless compression codec ... it should come out the other end much the same as it would without any compression, just taking up less disc space.
unless the rgb <--> yuv conversion is to blame?-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
The issue appears to arise if I export, via Huffyuv, as either a YUV or a RGB.
Here is a note, which may add some helpful details: If I export as a .wmv, the issue does not appear.
I think I may export as an uncompressed RGB and perhaps using another codec, such as Indeo, to see if this issue is reoccurring. I guess I was hoping it would be an issue with some configuration which I was overlooking, since I do like the quality to size encoding of Huffyuv vs. othe codecs.
Soecial Effects and Transitions Pack?
By MrVon in forum EditingReplies: 1Last Post: 29th Oct 2010, 22:12 -
56 Transitions and 21 Effects missing in Mac version of PrCS4
By ValterMac in forum MacReplies: 2Last Post: 10th Jul 2009, 10:32 -
By ValterMac in forum EditingReplies: 1Last Post: 10th Jul 2009, 07:40 -
Transitions, Animations and Video Effects
By MI6 in forum EditingReplies: 3Last Post: 9th Oct 2008, 12:10 -
Captured video has pixel noise on top edge of display
By cohoman in forum Capturing and VCRReplies: 0Last Post: 23rd Feb 2008, 19:32
