V 2.5 works fine with Vista Ultimate, but once started I can not maximize it to see what is happening. I just get a small box to let me know it is running. It completes OK, so I just have to guess whether it is finished or not. Any help please. Last LOG file attached..
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.2725.29477
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.58 MB
Executable size in bytes: 2715731
Executable CreationTime: 18/06/2007 16:23:26
Executable LastWriteTime: 19/06/2007 15:15:00
Executable LastAccessTime: 19/06/2007 15:15:00
************************* Operating System *************************
Operating System: Microsoft® Windows Vista™ Ultimate
Service Pack:
Version : 6.0.6000
Windows Directory : C:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 1.99 GB
Free Physical Memory: 928 MB
Total Virtual Memory: 4.19 GB
Free Virtual Memory: 3.07 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: System Product Name
System Type: X86-based PC
Computer Name: DENNIS-PC
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: Dennis-PC\Dennis
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+
Description: x64 Family 15 Model 35 Stepping 2
CPU Speed: 2.21GHz
CPU FSB: 200MHz
L2 Cache Size: 1.00 KB
19:33:16: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce 6800 GS
Processor: GeForce 6800 GS
Mode: 1440 x 900 x 4294967296 colors
Video Ram: 256 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 29.5 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 96.9 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 55.8 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="24/06/2007 19:33:16" Filename="NONE"><AssetSet><Asset ID="04a1711d-b52d-49db-93c5-01cb1fc4d885" Path="C:\Users\Dennis\Desktop\Uploads\Oceans.Twelv e.DVDRiP.XviD-BRUTUS\1" Filename="Oceans 12 Disc 1.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="Oceans 12 Disc 1.avi" AssetID="04a1711d-b52d-49db-93c5-01cb1fc4d885" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 700 MB
file=C:\\Users\\Dennis\\Desktop\\Uploads\\Oceans.T welve.DVDRiP.XviD-BRUTUS\\1\\Oceans 12 Disc 1.avi
FormatName=avi
Num_Frames=98847
DurationInSecs=4122
Duration=01:08:42.7
VideoCodec=mpeg4
VideoFFSTNum=0
Width=640
Height=272
Standard=NTSC (Film)
BitRate=1424
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=liba52
Audio1BitRate=448
Audio1Channels=6
AVI2MPG: 8360kbs Full-D1
19:33:16: Looking for AVI PAR...
Leaving source audio alone.
Pass 1/1: Processing Oceans 12 Disc 1.avi
19:33:17: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
19:33:17: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
19:33:17: libavutil version: 49.4.0
19:33:17: libavcodec version: 51.40.4
19:33:17: libavformat version: 51.12.1
19:33:17: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
19:33:17: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (2997/125)
19:33:17: Input #0, avi, from 'C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1.avi':
19:33:17: Duration: 01:08:42.7, start: 0.000000, bitrate: 1424 kb/s
19:33:17: Stream #0.0: Video: mpeg4, yuv420p, 640x272, 23.98 fps(r)
19:33:17: Stream #0.1: Audio: liba52, 48000 Hz, 5:1, 448 kb/s
19:33:17: Output #0, dvd, to 'C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2D.mpg':
19:33:17: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 8360 kb/s, 23.98 fps(c)
19:33:17: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
19:33:17: Stream mapping:
19:33:17: Stream #0.0 -> #0.0
19:33:17: Stream #0.1 -> #0.1
19:33:17: Press [q] to stop encoding
20:04:25: video:3000755kB audio:225451kB global headers:0kB muxing overhead 1.989024%
20:04:25: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing Oceans 12 Disc 1_S2D.mpg
20:04:26: FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
20:04:26: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-liba52 --enable-gpl --enable-libfaad --enable-avisynth
20:04:26: libavutil version: 49.4.0
20:04:26: libavcodec version: 51.40.4
20:04:26: libavformat version: 51.12.1
20:04:26: built on Jun 18 2007 13:04:11, gcc: 4.3.0 20061204 (experimental)
20:04:26: Input #0, mpeg, from 'C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film).mpg':
20:04:26: Duration: 01:08:42.5, start: 0.500000, bitrate: 6538 kb/s
20:04:26: Stream #0.0[0x1e0]: Video: mpeg2video, yuv420p, 720x480, 9000 kb/s, 23.98 fps(r)
20:04:26: Stream #0.1[0x80]: Audio: liba52, 48000 Hz, 5:1, 448 kb/s
20:04:26: Output #0, rawvideo, to 'C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film).mpv':
20:04:26: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=2-31, 9000 kb/s, 23.98 fps(c)
20:04:26: Output #1, ac3, to 'C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film).ac3':
20:04:26: Stream #1.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
20:04:26: Stream mapping:
20:04:26: Stream #0.0 -> #0.0
20:04:26: Stream #0.1 -> #1.0
20:04:26: Press [q] to stop encoding
20:07:54: video:3000755kB audio:225451kB global headers:0kB muxing overhead -6.988108%
20:07:54: NTSC(Film)->NTSC: Applying Pulldown Oceans 12 Disc 1_S2DNTSC(Film).mpv
20:07:54: SVCD2DVD: Convert2NTSC: Converting....
20:24:11: NTSC(Film)->NTSC: Muxing Oceans 12 Disc 1_S2D.mpg
20:32:29: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
20:32:29: INFO: [???] File C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVDR iP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
20:32:29: INFO: [???] File C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVDR iP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film).ac3 looks like an AC3 Audio stream.
20:32:29: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
20:32:29: INFO: [???] Found 1 audio streams and 1 video streams
20:32:29: INFO: [???] Selecting dvdauthor DVD output profile
20:32:29: INFO: [???] Multiplexing video program stream!
20:32:29: INFO: [???] Scanning for header info: Video stream e0 (C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film)_pd.mpv)
20:32:29: INFO: [???] VIDEO STREAM: e0
20:32:29: INFO: [???] Frame width : 720
20:32:29: INFO: [???] Frame height : 480
20:32:29: INFO: [???] Aspect ratio : 16:9 display
20:32:29: INFO: [???] Picture rate : 29.970 frames/sec
20:32:29: INFO: [???] Bit rate : 9000000 bits/sec
20:32:29: INFO: [???] Vbv buffer size : 229376 bytes
20:32:29: INFO: [???] CSPF : 0
20:32:29: INFO: [???] Scanning for header info: AC3 Audio stream 00 (C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVD RiP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2DNTSC(Film).ac3)
20:32:29: INFO: [???] AC3 frame size = 1792
20:32:29: INFO: [???] AC3 AUDIO STREAM:
20:32:29: INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
20:32:29: INFO: [???] Frequency : 48000 Hz
20:32:29: INFO: [???] SYSTEMS/PROGRAM stream:
20:32:29: INFO: [???] rough-guess multiplexed stream data rate : 9653896
20:32:29: INFO: [???] target data-rate specified : 10080000
20:32:29: INFO: [???] Setting specified specified data rate: 10080000
20:32:29: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022
20:32:29: INFO: [???] New sequence commences...
20:32:29: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
20:32:29: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
20:32:29: INFO: [???] STREAM bd completed @ frame 128828.
20:32:29: INFO: [???] STREAM e0 completed @ frame 98845.
20:32:29: INFO: [???] Multiplex completion at SCR=371038354.
20:32:29: INFO: [???] Video e0: buf= 218995 frame=098845 sector=01521606
20:32:29: INFO: [???] Audio bd: buf= 1792 frame=128828 sector=00114515
20:32:29: INFO: [???] VIDEO_STATISTICS: e0
20:32:29: INFO: [???] Video Stream length: 3072773379 bytes
20:32:29: INFO: [???] Sequence headers: 8238
20:32:29: INFO: [???] Sequence ends : 0
20:32:29: INFO: [???] No. Pictures : 98846
20:32:29: INFO: [???] No. Groups : 8238
20:32:29: INFO: [???] No. I Frames : 8238 avg. size 49784 bytes
20:32:29: INFO: [???] No. P Frames : 24712 avg. size 35422 bytes
20:32:29: INFO: [???] No. B Frames : 65897 avg. size 27122 bytes
20:32:29: INFO: [???] Average bit-rate : 5962400 bits/sec
20:32:29: INFO: [???] Peak bit-rate : 10036800 bits/sec
20:32:29: INFO: [???] BUFFERING min 15 Buf max 187933
20:32:29: INFO: [???] AUDIO_STATISTICS: bd
20:32:29: INFO: [???] Audio stream length 230861568 bytes.
20:32:29: INFO: [???] Frames : 128829
20:32:29: INFO: [???] BUFFERING min 35 Buf max 7427
20:32:29: INFO: [???] MUX STATUS: no under-runs detected.
20:32:31: Done: Processing assets for DVD creation
Authoring DVD Folders
20:32:31: Creating TitleSet # 1
20:32:32: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
20:32:32: -->: DVDFolders creating VTS
20:32:32: -->: VTS 01
20:32:32:
DVD Folders: Processing C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVDR iP.XviD-BRUTUS\1\Oceans 12 Disc 1_S2D.mpg...
20:36:13:
20:38:48:
20:38:48: Finalising DVD...
20:38:48: SVCD2DVD: DVDfolders
20:38:48: -->: DVDFolders creating table of contents
20:38:48: scanning C:\Users\Dennis\Desktop\Uploads\Oceans.Twelve.DVDR iP.XviD-BRUTUS\1\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
20:38:48: Finalising DVD...Done
20:38:48: Done: Authoring DVD Folders
Results 1 to 1 of 1
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 06:51 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 19:59 -
Is there a possibility to...mark certain timespaces to maximize the bitrate
By waefwaeefwaefw in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 15:00 -
WinDV is "off the screen" unless I maximize it
By Ken Kaiser in forum Capturing and VCRReplies: 3Last Post: 23rd Feb 2008, 20:40 -
Can't maximize preferences window in 2.5
By maxxjulie in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 28th Jun 2007, 18:48
