    Apr 2003
    I've not used ImgBurn before, but I want to learn it because I just got my first dual-layer DVD burner and so many users seem to love this program. And I apologize, because I don't fully understand the couple of guides I've read through. Here are my questions?
    1. After using DVD Decrypter to rip a movie to my computer, will ImgBurn alone allow me to burn the movie to DVD+R DL?
    1a. If "no," then what other program(s) do I need?
    1b. If "yes," then could a kind individual point me in the right direction? I'm a little confused between the "build" mode, the "write" mode, and the overall process of getting a movie onto a DVD+R DL.
    I've already read that Verbatim DVD+R dual-layer is the best media for the job, so now I just need to learn how to do the job. Thanks so much if you're able to help!
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Insert blank disc.
    See if it is detected and listed as "destination".
    Build mode: Select the files and folders to burn.
    For a DVD video, just pick the VIDEO_TS folder
    Now you can just click the triangle button to burn.
    Optional:
    select "verify" to check it back.
    Device tab: can change the writing speed. But it should be okay as-is.
    Options-file system: choose "ISO9660 + UDF"
    Feb 2003
    U.S.A.
    Build Mode is if the original files are not an ISO image, but in a folder structure. This mode will convert to ISO image so it can be burned. If it's already an ISO image, then Write Mode is all you need.
  4. OP:why not use DVDDecrypter to burn ISO files?Just select the MDS file and away you go.
  5. ...C O P Y L E F T JohnnyBob's Avatar
    Feb 2007
    Earth
    [snip]
    Yes. Here's the step-by-step guide I used...
    http://forum.imgburn.com/index.php?showtopic=1780
    Feb 2004
    Australia
    1: http://www.free-codecs.com/download/DVDFab_Decrypter.htm
    Dont use dvddecryter , nolonger updated , dosent handle newer protection methods .
    Then follow advice of burning .
    Apr 2003
    Thanks for the good help! It makes sense & I think I can make it work. Thank you!
