I have just bought a Sharp TV, the DVD/VCR is on av2, when i watch the tv, DVD or video through av2 the colour is very green, the picture is fine through sky (av1) and the external ariel. I tried the DVD through another TV and it was fine, I also tried another DVD on the sharp tv and that was fine. Any ideas what the problem may be? Thanks
Is the dvd thats green region 1 and are you using scart connectors? if you have cheap scarts they don't always have all of the connections wired to the pins in the plug ,also only certain av inputs on your tv will cope with nstc playback.
I am using the same scart that i was using on the old TV, when there was no problem, also when i tried a different DVD with the same scart that was not a problem! I have tried the scart leads in both AV ports. I have not tried to adjust the colour on the TV as the TV is fine on sky and the normal ariel. You said about the DVD being region 1, would that not have caused a problem with the old TV. Thanks
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 17:41 -
black in picture turns green
By heticu in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 14:51 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00 -
why do mpegs play with green flashing lines obscuing the picture??
By cyberraga in forum Software PlayingReplies: 1Last Post: 13th Dec 2007, 15:57
