I've been using 2.1 until I upgraded to 2.5 a week ago. I can't access all the settings in the preferences cuz the window can't be maximized like in 2.1. My burner can burn 8x discs @12x and 16x and the default burn speed is max in the preferences. I can't change it from max to 8x cuz I can't see those settings. I made two dvd's with 2.5 and one was a coaster cuz it burned @16x. i know I could just burn it afterwards, but it's more convenient when svcd2dvd has it all burned and ready for me. can you fix this in the next update? Just make it so the preferences screen can be maximized like in 2.1. I think the problem is I have a big monitor and i changed the font size so it's a lot bigger. That's why I'm not seeing the menu and burning settings in the preferences.
In the meantime you could change the font, adjust the settings and change the font back. Just a thought.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Rebooting huh? Mine does it on the fly under 'Display Properties -->Appearance'. What's your OS?
Dwight
- Herm Albright
This is resolved = please redownload and you can now resize the form:
https://forum.videohelp.com/topic332098.html#1721536SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Changing VLC or MPC settings to maximize quality?
By awaisuk in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2011, 07:51 -
Problems with display of File / Preferences
By Lehmeier in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2011, 06:06 -
Is there a possibility to...mark certain timespaces to maximize the bitrate
By waefwaeefwaefw in forum Video ConversionReplies: 3Last Post: 15th Jan 2009, 16:00 -
Take Preferences, Vegas 6.0
By solarblast in forum AudioReplies: 0Last Post: 24th Nov 2008, 11:52 -
Cant maximize when running
By Perfik in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 25th Jun 2007, 08:40
