I have a problem...
when i'm converting a divx movie to Mpeg1 (VCD) with the program TMPGenc, option PAL. I get a (sort of) pause after each keyframe (about 2/3 seconds) its very short and almost not noticable, but it is there.. and it bugging the crap out of me!!![]()
But when i encode with NTSC or NTSCFilm... it's not there..
i choose the standard Video-cd PAL / NTSC /NTSCFilm template's
Although my DVD player playes both, PAL and NTSC, i find PAL better quality..
pppppppppppllllllleeeeeeeaaaaaaassssseeeeeee![]()
help me..
as long as my boss thinks i make a lot of money, i will pretend to work hard ;)
You can't just select a Template, you must make sure the Template fits the file you want to encode, if your file is 23.97 or 29 or 30 fps, then use NTSC or NTSC Film, if your file is 25fps then use PAL, and only for that type.
There is also the resolution, NTSC/Film use 352x240, and PAL uses 352x288, so make sure you match the AVI and the Template, or it will cause you those problems.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
... i forgot all about that rule.... thanks 4 reminding me!!!
but i checked, and most of the files are, according to; properties\summary... in explorer.. 23 (frame rate)
should i than choose ntscfilm, because that one comes near it.....as long as my boss thinks i make a lot of money, i will pretend to work hard ;) -
You could either use the NTSC Film, or you could use that 3:2 Pulldown with regular NTSC, both might work (I could be wrong on the pulldown, I always mix it with the other one, I think telecine).
Best Regards,
Sefy Levy,
I have had this problem when converting NTSC DVDs to PAL XVCD.
I fixed it by deinterlacing. I forgot which option I used but play around with them and make some short sample to test which one works. Try also changing the "field order" in settings>advanced.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Pal to NTSC conversion ;o)
By StrobeLightEpileptic in forum Video ConversionReplies: 112Last Post: 30th Jun 2009, 17:59 -
PAL to NTSC DVD Conversion Problem
By squallx404 in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 05:16 -
HELP: PAL to NTSC conversion
By hydrophonicaudio in forum ffmpegX general discussionReplies: 5Last Post: 15th Jul 2007, 09:24 -
NTSC to PAL-M RF conversion
By ptannjr in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 13:38
