Anyone know hove to change movie resolution as is on this picture
Well from what I can tell simply setting the above profiles will set the auto resize to the above resolutions, that is as long as it is downsizing. It won't upsize, which makes sense since that would only waste bits. You can set the video resize to whatever you like though.
Well if your source is 720p or greater it should do it automatically. If your source is < 720p, then it would be a waste of time and bits to upsize, just encode at 576p or whatever the source is and let the player upsize.
What should resolution of photo be when added to DVD movie
By johnharlin in forum Video ConversionReplies: 3Last Post: 8th Mar 2011, 00:40 -
HD Movie resolution problem
By Penicillin in forum DVB / IPTVReplies: 3Last Post: 21st Jul 2010, 15:18 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
leadtek dtv1000t digital tv tuner card capture resolution.
By g12345567 in forum DVB / IPTVReplies: 4Last Post: 22nd Jul 2007, 11:56 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06
