I recently brought this phone and absolutely love it. What I would like to know is when I convert movies for this mobile what software, codec, resolution, bitrate I use and preferably support for subs which I assume needs to be hardcoded? I would need the max quality with minimum space usage of course.
thanks
Super has nokia 3gp support .
As for subs , they may need to be hard coded into the video prior to using super to convert to 3gp
Virtualdub / mod + vobsub
http://www.downloadjunction.com/product/freeware/69129/index.html
SPECIFICATIONS:
160MB dynamic memory; 2.6in 240 x 320 screen; 5MP camera; USB; Bluetooth; Quad-band GSM, GPRS/EDGE, HSPDA; 802.11b/g; GPS; microSD slot; 53 x 21 x 99mm (WDH); 120g.
Only suitable for videos nolonger than a few minutes .
Apparently the battery takes a pounding from using bluetooth
Everything else should be in the manual that came with it ... on the cd .
Sony Vegas N95 settings
By Abas-Avara in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jan 2010, 10:28 -
Video from N95...enhancement software?
By coolchrisyorkshire in forum EditingReplies: 5Last Post: 1st Nov 2008, 12:38 -
Question about converting media files to a mobile telephone (Nokia N95)
By nadizo in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 22:16 -
Converting video for use on Nokia N95
By daiver in forum Portable VideoReplies: 5Last Post: 12th Jan 2008, 03:00
