I finally ripped a DVD to DVD+RW that plays on my standalone. Ripped with DVD Decrypter in ISO mode and then burning image using ULEAD DVD Movie Factory. Ripping in file mode with Decrypter, Smart Rip, or Clad and burning with NERO has been unsuccessful. ISO is fine for the smaller originals but I can't remove extras from the big disks in ISO format. Can someone explain why the ISO is working and I can't rip and burn with the file mode?
did you burn in udf/iso mode in nero? if so I dont know why...because it worked for me.
Yes, I did burn in UDF/ISO. I used two different guides I found for Nero and everything I found said to use that format. I tried both ISO level 1 and 2, Joliet disabled/enabled both and have had no luck. The guides I've found do not talk specifically about any switches other than addressing UDF/ISO format and disabling Joliet, does anyone know of a guide that provides details for the other switches? THANKS
Y,
In regards to ISO vs. File backups, I was wondering when you utilized SmartRipper, did you select BACKUP from the left menu or did you select Movie? Reason being is that I backed up a DVD of mine recently using the BACKUP option. I then burned the Video _TS folder to DVD-R with my Pioneer A03 and it plays fine on both my Apex 703 and Pioneer 434.Regards,
The Daywalker
Rip VCD to ISO without converting
By cynikalhedonist in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Mar 2011, 12:50 -
Rip the contents of home DVDs without it locking up the whole works?
By DB83 in forum MediaReplies: 3Last Post: 5th Dec 2010, 10:40 -
Using dd to rip a dvd movie to an iso file - seriously slow
By graysky in forum LinuxReplies: 1Last Post: 10th Apr 2009, 14:36 -
ISO doesn't preserve 5.1 soundtrack?
By UncleBose in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2008, 22:26 -
.srt sometimes works.. sometimes doesn't
By jaxwire2003 in forum SubtitleReplies: 3Last Post: 19th Feb 2008, 08:03
