Hi
I'm a bit dubious about posting this as I posted it on another site and was told that it was "the second dumbest post ever", so I apologise in advance if I'm being really thick![]()
I used DVDFlick to convert an AVI file so that I could burn it to DVD (I want to be able to watch in on my standalone DVD player). I thought the conversion had gone fine but I just can't get it to burn it fails every time. Does this mean that the conversion did in fact go wrong?
I really would appreciate any help.
Nothing 'dumb' about it.
Do you have a VIDEO_TS folder? You can look to the upper left on this page for 'WHAT IS' DVD to see the DVD specifications and format. You need to adhere to that to have a compliant DVD that will work on most set top players.
If you have the folder, you could always try burning it with the freeware ImgBurn using the 'Build' mode with your VIDEO_TS folder. -
I do have a VIDEO_TS folder and its Imgburn I'm using to try and burn it.
This is the imgburn log after a failed burn:-
I 13:33:22 ImgBurn Version 2.3.2.0 started!
I 13:33:22 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 2)
I 13:33:22 Total Physical Memory: 523,744 KB - Available: 210,440 KB
I 13:33:22 Initialising SPTI...
I 13:33:22 Searching for SCSI / ATAPI devices...
I 13:33:23 Found 1 CD-RW and 1 DVD±RW!
I 13:34:26 Operation Started!
I 13:34:26 Source File: C:\Documents and Settings\computer\My Documents\New Folder\dvd.iso
I 13:34:26 Source File Sectors: 1,372,688 (MODE1/2048)
I 13:34:26 Source File Size: 2,811,265,024 bytes
I 13:34:26 Source File Volume Identifier: DVD
I 13:34:26 Source File Application Identifier: IMGBURN V2.3.0.0 - THE ULTIMATE IMAGE BURNER!
I 13:34:26 Source File Implementation Identifier: ImgBurn
I 13:34:26 Source File File System(s): ISO9660, UDF (1.02)
I 13:34:26 Destination Device: [1:0:0] LITE-ON DVDRW SOHW-812S US05 (E
(ATA)
I 13:34:26 Destination Media Type: DVD-RW (Disc ID: OPTODISCW004) (Speeds: 1x)
I 13:34:26 Destination Media Sectors: 2,297,888
I 13:34:26 Write Mode: DVD
I 13:34:26 Write Type: DAO
I 13:34:26 Write Speed: 4x
I 13:34:26 Link Size: Auto
I 13:34:26 Test Mode: No
I 13:34:26 BURN-Proof: Enabled
I 13:34:27 Filling Buffer... (20 MB)
I 13:34:27 Writing LeadIn...
I 13:35:55 Writing Image... (LBA: 0 - 1372687)
W 13:44:47 Failed to Write Sectors 353248 - 353279 - Write Error
W 13:44:47 Retrying (1 of 20)...
W 13:44:47 Retry Failed - Command Sequence Error
W 13:44:47 Retrying (2 of 20)...
W 13:44:47 Retrying (3 of 20)...
W 13:44:48 Retry Failed - Command Sequence Error
W 13:44:48 Retrying (4 of 20)...
W 13:44:48 Retrying (5 of 20)...
W 13:44:48 Retrying (6 of 20)...
W 13:44:48 Retrying (7 of 20)...
W 13:44:48 Retrying (8 of 20)...
W 13:44:48 Retrying (9 of 20)...
W 13:44:48 Retrying (10 of 20)...
W 13:44:49 Retry Failed - Command Sequence Error
W 13:44:49 Retrying (11 of 20)...
W 13:44:49 Retrying (12 of 20)...
W 13:44:49 Retrying (13 of 20)...
W 13:44:49 Retrying (14 of 20)...
W 13:44:49 Retrying (15 of 20)...
W 13:44:49 Retrying (16 of 20)...
W 13:44:50 Retry Failed - Command Sequence Error
W 13:44:50 Retrying (17 of 20)...
W 13:44:50 Retrying (18 of 20)...
W 13:44:50 Retrying (19 of 20)...
W 13:44:50 Retrying (20 of 20)...
W 14:04:59 Retrying (21)...
W 14:04:59 Retry Failed - Command Sequence Error
E 14:05:00 Failed to Write Sectors 353248 - 353279 - Write Error
I 14:05:00 Synchronising Cache...
E 14:05:01 Failed to Write Image!
E 14:05:01 Operation Failed! - Duration: 00:30:35
I 14:05:01 Average Write Rate: 404 KB/s (0.3x) - Maximum Write Rate: 1,391 KB/s (1.0x) -
Known to have some issues , check for firmware update ... but consider using a dvd-r , verbatim or ty firstDestination Device: [1:0:0] LITE-ON DVDRW SOHW-812S US05 (E (ATA)
Dvd-rw > as before , try dvd-r , 4x burn , max file is 4.3gigI 13:34:26 Destination Media Type: DVD-RW (Disc ID: OPTODISCW004) (Speeds: 1x)
Try again . -
A one speed disc?
The reviews here for that disc aren't good.
https://www.videohelp.com/dvdmedia/optodisc-dvd-r-optodisc-1/39 -
That'll teach me to use discs a mate gave me!
I'll be off to get Verbatim!
Nero burning 'Communication Failure'
By geo g in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2010, 16:32 -
laptop failure
By romanstopme in forum ComputerReplies: 6Last Post: 21st Feb 2010, 08:23 -
Nero failure burning "Audio & Data cd"
By spiritgumm in forum AudioReplies: 4Last Post: 15th Oct 2008, 16:25 -
AVIsynth failure in VD
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jan 2008, 04:08 -
Why MP2? Then why failure?
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 22nd Jun 2007, 05:32
