Hello,
Just a quick question:
Does the re-encoding make watermark permanent? For example, I have an AVI videoclip that is watermarked, if reencoded to MPG format, is there any way I can remove the watermark from new MPG file?
Please guide.
PLEASE PLEASE use our search, I tried search for remove watermark and found for example https://forum.videohelp.com/topic305643.html?highlight=remove%20watermark .
Watermarks on videos are usually permanent to begin with, so if you encode the video to another format, it'll still be there. One exception is if it's your codec or player software displaying a watermark over the video while it's playing.
What kind of watermark do you have?If cameras add ten pounds, why would people want to eat them? -
OK, let me re-phrase the question (or my original problem);
I want to add a watermark on a video clip that could be removed by only me.
Now why I asked the first question is because I know that when you are adding a watermark, it means you are changing the frequency domain characteristics of the video signal and the process could be reversed if you know exactly the timing information and amount of information is being added. BUT, if you transcode the video (e.g., change from AVI to MPG) the original frequency domain informations are lost and it is almost impossible to remove the watermark completely from the reencoded video.
So back to first question, is there any way I can get the transcoded video without watermark?
Any suggestion? Any links? I tried to search on this forum but no luck. Also, googled it but no satisfactory answer there.
Watermark quandary....
By hd28qi in forum Newbie / General discussionsReplies: 12Last Post: 4th Feb 2011, 14:47 -
How to add watermark to VCD without Re-Encoding?
By shebi in forum Authoring (VCD/SVCD)Replies: 25Last Post: 26th Apr 2009, 10:26 -
Watermark on MP4
By zirkov in forum Newbie / General discussionsReplies: 0Last Post: 21st Feb 2008, 13:23 -
WATERMARK help!
By legendvij in forum SubtitleReplies: 9Last Post: 13th Feb 2008, 02:52 -
Increasing Encoding Speed?? What Hardware makes it run faster?
By sandman423 in forum Newbie / General discussionsReplies: 15Last Post: 25th Jan 2008, 23:09
