After downloading a divx movie from kazaa, the dat should become a (avi), but does not change. The download window shows the download it complete but their dat has not changes to avid.
Why has this happen any one know?
[/code]
Probably just a program error, never had it happen to me. Have you tried just renaming the file yourself?
Go here and have a look at this.
This is for morpheus and it is an enhancer that looks for more sources every 5 minutes.
It will work for Kazaa as well but the point is when you are there there is a section on DAT Repair and a free tool to do it with.
Also try reinstalling your kazaa software.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
