How do I convert Mpeg4 video into something I can edit with my vid software?
Results 1 to 10 of 10
Gatefan810
more info about your video?
using gspot?
more info about your vid software?
What are you doing?
DV is the preferred editing format.
You can go to DV with vdub and the cedocida DV codec.
gl -
This isn't video bought from the iTunes Music Store, is it? If it is, it'll be DRM-encoded, which means most converters won't be able to do much with it as-is.Need to add some clips that are mp4 video. (iTunes)If cameras add ten pounds, why would people want to eat them?
Yes, it is. I just need little bits from the movies, don't need to backup the whole thing.Originally Posted by Ai HaibaraGatefan810
https://www.videohelp.com/forum/archive/itunes-video-file-to-dvd-t289111.html < tips
http://tunebite.com < product capable of removing drm
Sceen recording with camstudio require disabling the hardware acceleration for graphics card ... dreaded black captures if enabled ... they still havent capped that in the butt ... yet . -
Guns1linger,
Yeah you're right it just screencaps it to 3ivX, which will further deteriorate the OP's quality by the time they get it to an editor. -
Well, I've decided I'm better off not using those movies. I'm a newbie and already lost. I ended up with plenty of clips to go along with the song, even have to give up some of them to shorten the production.
Thanks so much for your help though!Gatefan810
Video/audio TS files convert to an uploadable MPEG video
By Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 15:30 -
How to convert Mov video files to Mpeg
By Tintin11 in forum Video ConversionReplies: 4Last Post: 8th Dec 2010, 09:14 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
How to Convert Quicktime MOV Video Files to MPEG-2
By hiroprot in forum Video ConversionReplies: 8Last Post: 10th Nov 2008, 10:54 -
Video corruption when trying to convert MPEG-2 to DVD-compliant
By DB83 in forum Video ConversionReplies: 2Last Post: 31st Jan 2008, 20:00
