Getting the following error. Source files were produced by VOB2MPG 2.3 from a PAL DVD. My intention was to produce a NTSC DVD disk. Failed twice with SVCD2DVD with same error. I believe the error occurred at roughly the same place in the process. No problem when I use ConvertXtoDVD with the same source files.
Version: SVCD2DVD 2.5
Build: 2.5.2728.36230
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99 x50afe96f7df19242, xcbd1127f90d7945f x3146d638ec378671)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
The log of the session reads as follows...
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.2728.36230
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.57 MB
Executable size in bytes: 2703443
Executable CreationTime: 6/22/2007 04:20:52 AM
Executable LastWriteTime: 6/22/2007 11:47:04 AM
Executable LastAccessTime: 6/22/2007 11:47:04 AM
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 0.99 GB
Free Physical Memory: 579 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.95 GB
***************************** Computer *****************************
Computer Manufacturer Name: VIA Technologies, Inc.
Computer Model: VT8363
System Type: X86-based PC
Computer Name: COOTIE
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 1800+
Description: x86 Family 6 Model 6 Stepping 2
CPU Speed: 1.532GHz
CPU FSB: 133MHz
L2 Cache Size: 256 bytes
***************************** Time Zone ****************************
Time Zone: (GMT-05:00) Eastern Time (US & Canada)
****************************** VIDEO *******************************
Name: Matrox Millennium G450 DualHead - English
Processor: Matrox G450
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 32.0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 4.03 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 80.9 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 57.4 GB
DeviceID: L:
FileSystem: NTFS
FreeSpace: 39.0 GB
DeviceID: M:
FileSystem: NTFS
FreeSpace: 16.6 GB
DeviceID: N:
FileSystem: NTFS
FreeSpace: 43.7 GB
DeviceID: O:
FileSystem: NTFS
FreeSpace: 9.16 GB
DeviceID: P:
FileSystem: NTFS
FreeSpace: 26.9 GB
DeviceID: Q:
FileSystem: NTFS
FreeSpace: 35.8 GB
DeviceID: V:
FileSystem: NTFS
FreeSpace: 110 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="6/23/2007 08:15:29 AM" Filename="NONE"><AssetSet><Asset ID="a3b01dec-2b44-451a-aeed-a566b89a8e70" Path="V:\ToProcess" Filename="VTS_01.mpg" /><Asset ID="760d76e1-5f14-4e2a-92f8-a1b8545114c0" Path="V:\ToProcess" Filename="VTS_02.mpg" /></AssetSet><DVDStructure><TitleSet Name="Requiem For A Dancer" PostCmd="" MenuButtonType="0"><MenuButton X1="139" Y1="353" X2="582" Y2="406" FontFamily="Tahoma" FontSize="28" FontStyle="3">Requiem For A Dancer</MenuButton><Title Name="VTS_01.mpg" AssetID="a3b01dec-2b44-451a-aeed-a566b89a8e70" MplexOffset="0" /></TitleSet><TitleSet Name="Najinsky: A Life" PostCmd="" MenuButtonType="0"><MenuButton X1="219" Y1="406" X2="534" Y2="459" FontFamily="Tahoma" FontSize="28" FontStyle="3">Najinsky: A Life</MenuButton><Title Name="VTS_02.mpg" AssetID="760d76e1-5f14-4e2a-92f8-a1b8545114c0" MplexOffset="0" /></TitleSet><DVDMenu Normal="-128" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="P:\DVDBackgrounds\Silhouette-of-Male-Ballet-Dancer.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="E:\Post-Processing" InitialDVDFolder="D:\SVCD2DVD" InitialProjectFolder="C:\Program Files\BadgerIT\SVCD2DVD v2.5\Projects" InitialMenuBackgroundFolder="P:\DVDBackgrounds" DeleteS2DFiles="True" UseDVDShrink="False" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 5 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="False" ForceWS="False" SafeMaxBitRate="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 648 MB
file=V:\\ToProcess\\VTS_01.mpg
FormatName=mpeg
Num_Frames=29012
DurationInSecs=1160
Duration=00:19:20.5
VideoCodec=mpeg2video
VideoFFSTNum=1
Width=704
Height=576
Standard=PAL
BitRate=4684
AudioStreamCount=1
Audio1FFSTNum=0
Audio1StreamID=[0x80]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=256
Audio1Channels=2
Processing VTS_01.mpg
Leaving source audio alone.
08:15:29: Converting PAL to NTSC (DVD Profile)
08:15:30: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
08:15:30: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
08:15:30: libavutil version: 49.1.0
08:15:30: libavcodec version: 51.27.0
08:15:30: libavformat version: 51.12.1
08:15:30: built on Jun 21 2007 20:15:44, gcc: 4.3.0 20061204 (experimental)
08:15:30: Input #0, mpeg, from 'V:\ToProcess\VTS_01.mpg':
08:15:30: Duration: 00:19:20.5, start: 0.500000, bitrate: 4684 kb/s
08:15:30: Stream #0.0[0x80]: Audio: ac3, 48000 Hz, stereo, 256 kb/s
08:15:30: Stream #0.1[0x1e0]: Video: mpeg2video, yuv420p, 704x576, 9556 kb/s, 25.00 fps(r)
08:15:30: Output #0, dvd, to 'V:\ToProcess\VTS_01_S2D.mpg':
08:15:30: Stream #0.0: Video: mpeg2video (hq), yuv420p, 704x480, q=1-31, 6000 kb/s, 25.00 fps(c)
08:15:30: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 256 kb/s
08:15:30: Stream mapping:
08:15:30: Stream #0.1 -> #0.0
08:15:30: Stream #0.0 -> #0.1
08:15:30: Press [q] to stop encoding
09:02:13: video:850385kB audio:36270kB global headers:0kB muxing overhead 2.006719%
PAL->NTSC: demuxing VTS_01_S2D.mpg
And that's where it stops with the popup error listed at the beginning.
Just as an aside question - Is there an easier way to produce a NTSC version of a PAL disk using SVCD2DVD directly without using VOB2MPG? Maybe I'm missing the obvious but it doesn't appear that SVCD2DVD can do it.
Results 1 to 10 of 10
Well it looks strange.. is there anyway you can get VTS_01.mpg to me for testing? Or if i give you an FTP can you upload it? If not i have a new version (which could be available next week) which would more than likely resolve this (it wouldn't need to do that demuxing step)....
Currently SVCD2DVD just processes assets (as you know) and so doesn't analyse DVD structure etc.. So you need to provide the asset - and thats where Vob2mpg comes in. I have another tool which does analysis DVDs and produces mpegs based on PGC/Chapters/Titles etc. I may combine that tech into SVCD2DVD or create a new pal to ntsc tool soley to address the issue.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Absolutely, I can FTP it to you or whatever way you want it. Let me know how to get it to you.Originally Posted by ChrissyBoy
I have sent you a PM with the FTP details.
i have a similar error message with HDTV2DVD and it reads as follows:
Version: HDTV2DVD 0.4
Build: 0.4.2132.24074
Source: HDTV2DVD
InnerException:
StackTrace: at x14ee85f5d732c07f.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at x14ee85f5d732c07f.xd3764d4f1e921081.x2e6504f39decc 498()
at x14ee85f5d732c07f.xd3764d4f1e921081.xf81783e1b359f fc3() -
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
two identical error messages pop up and then i "x" them both out and then the program just sits there at 0% progress. does SVCD2DVD convert HD content to DVD? all i want is to convert the .mkv files i download into a mint quality DVD so i can watch it on my home DVD player. i have successfully taken the .mkv files and converted to Blu-Ray format and burned the Blu-Ray files to DVD-9 DL disc, but i want to get good quality DVD movies from the .mkv files. otherwise i am just going to continue converting to Blu-ray and wait til i get a BD player.
SVCD2DVD will handle the conversion to DVD.
Dwight
- Herm Albright
Hi Chrissy
Firstly thanks for creating such a good bit of kit.
I too seem to be getting this message in the middle of burning a DVD (see below).
Your guidance would be much appreciated
Regards
Hugh
Build: 2.5.3600.0
Source: SVCD2DVD
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x24919c2ff8f0c 9b2()
at System.Threading.ThreadHelper.ThreadStart() -
Can you post your log file?Originally Posted by capthugeca
What program are you using to burn?Dwight
- Herm Albright
New to SVCD2DVD Help!!!
By Marts1988 in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2011, 12:45 -
Svcd2dvd
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Apr 2010, 05:55 -
SVCD2DVD
By mr nice in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 27th Sep 2009, 13:41 -
svcd2dvd
By tempac in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 13th Mar 2008, 22:43
