Hi,
I have a 480*204 video. So it's a 2.35:1 ratio. I'd like to encode it to DVD.
What is better, resize and add huge black bars and encode to 4:3 or it's better for average quality to encode it to 16:9 anamorphic and let the tv/dvd add black bars (the video will be watched on a regular 4:3 TV) ?
Thanks.
I would imagine that if you make a 4:3 letterboxed DVD that the quality will look better this way on a 4:3 TV but will suffer on a 16x9 WS TV.
If you make a 16x9 anamorphic widescreen DVD then the quality will be better for a 16x9 WS TV but on a 4:3 TV may not look as good as if you made it 4:3 letterboxed BUT this difference will be very slight.
So I would make it 16x9 anamorphic widescreen since you may want to watch it in the future on such a TV.
Use FitCD to get your resize values and AviSynth script (if you use AviSynth).
Here is my FitCD mini-guide: CLICK HERE
I would let the bitrate be your guide. If you're forced to use a low bitrate go with letterboxed 4:3. If you can use high enough a bitrate go with anamorphic.
Turning on the deblocking filters in the Divx or Xvid decoder will help.
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
Letterbox 4:3 to Anamorphic 16:9
By sjdean in forum Video ConversionReplies: 4Last Post: 29th Nov 2009, 16:09 -
anamorphic 16:9 DV treated as 4:3 DV !?
By arminio in forum Video ConversionReplies: 4Last Post: 12th Mar 2008, 11:03 -
Test for Anamorphic?
By Nelson37 in forum Newbie / General discussionsReplies: 25Last Post: 28th Sep 2007, 19:16
