I bought a Certified DivX DVD Player, and I usually burn 6 AVI (DivX/Xvid) movies on 1 single Data DVD and watch them.
Is there a way to add the subtitle and watch the movie with the subtitles?
I guess I can merge the subtitle with the Video file to create a video file that’s contains the subtitle.
But is there a way to add the subtitle file separately, so the video file will stay untouched and to save time.
wow thats really great
i'll try it asap
I guess my DVD Player should be able to do it if it's doable cuz I bought the latest sony model (I hope) -
SRT format generally works best. You can put it in an external file. Some player require you to name the subtitle and the movie file with the same name, like this:
MYFILM.AVI (name of the movie)
MYFILM.SRT (name of the subtitles file)
Other players, such as Philips, don't care and you can name the movie and subtitle file anything you like, you just have to select the subtitle file first before playing the movie as that associates the subtitle file with the AVI file you want to play. If you mux the subtitles into the container, you should be aware that unless the player is Divx 6 certified that it probably won't recognize the subtitles. The safest way to make this work is to keep the subtitles in a separate file.
Finally, do note that while many standalone DVD player that support Divx support subtitles, the SUB format that they often claim to support is a text based format that is not in any way related to the image files that Subrip produces and Subrip subtitle files rarely work on standalone players.
Divx certified DVD player help...
By mjl1297 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 30th Apr 2011, 11:48 -
Would Philips be #1 certified DivX DVD Player?
By rocky12 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 20th Nov 2008, 22:12 -
transcoding for divx-certified player
By n8gray in forum LinuxReplies: 31Last Post: 20th Mar 2008, 16:34 -
Is there a list of supported resolutions for DivX certified DVD players?
By quitearush in forum DVD & Blu-ray PlayersReplies: 2Last Post: 12th Jan 2008, 06:26 -
Divx Certified dvd player won't recognize 16x9 aspect ratio
By maca in forum DVD & Blu-ray PlayersReplies: 3Last Post: 30th Nov 2007, 13:48
