Hey guys!
I have an AVI file thats has a little bit of a audio problem,
The problem is during the 1st 40mins of the clip the audio is out by about 250m/secs then the rest of the clip is in sync, i have managed to locate where this change over happens and was wondering if there is a program i could use just to split the file into 2 files (part1 and 2) that would be simple and efficenient to use?
What i then plan to do is use VirtualDubMod to sort out the audio/video snyc problem in the first part of the clip.
use the mark in /out points in virtual dub mod to split the file ,set the end at the point of the problem,note the frame number that you set the end point of the first section and save it,now go back to the frame number you wrote down and set it as your start point ,then set the end point to the end of the avi and then save this section.Make sure you select direct stream copy or your file will be massive.
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 02:59 -
MiniDV to DivX/XviD (w/ AutoGK): audio out of synch due to dropped frames??
By alexon in forum Video ConversionReplies: 6Last Post: 17th Dec 2009, 03:54 -
video stutter due to audio?
By rallynavvie in forum AudioReplies: 3Last Post: 29th Mar 2008, 13:19 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
