Results 1 to 10 of 10
  1. I really need help here guys.
    I have bin/cue files created with DVD2SVCD and have tried burning them using both Nero and DAO. Both write OK but are not playable in my Samsung 709 or Denen 3000 , even though it says they are capable.
    I tried making a simlpe VCD slide show in Nero, but the same thing happened. Burns OK but wont work.
    Setup: Athlon 1.4Ghz AMD. Win 2K & Win 98 (Tried both). HP 9200 CDRW SCSI cd writer.
    Any suggestions would be more than welcome please guys as Im lost as to what I can try next.
    :cry:
    QLD Ozwegia
    Yo Martin,
    I too use DVD2SVCD and create the bin & cue files. Burn via Nero 5.5.3. My player (Omni 3102) has no probs playing SVCD on CD-r or CD-RW. Via the players compatability list to the left I see the Smasung might not like CD-R media. Have you tried burning to CD-RW? Maybe just a small test vid? BTW My system 1600+XP and Win98SE. Don't think it's a PC problem here. Try CD-RW.
    Regards
    Studebarc
  3. Thanks, Ill try tonight.
    Does the type or quality of CDRW make any difference? Is the cdRW to be closed to all new writing or leave it in state it can be rewritten to?
    QLD Ozwegia
    Martin,
    Make it a closed session to be sure. BTW DVD2SVCD is possibly the BEST SVCD maker out there. Agree? R U using Vers 1.06 build 1?
    Cheers
    Studebarc
  5. It was the bundle version from doom9.org, so I amagine it will be the latest.
    Tks.
  6. Ive just checked on the list. My samsung player doesnt support CDR (Ive seen forum message saying it does), so ill try with CDRW. My denon should support both., as well as VCD and SVCD.
    QLD Ozwegia
    Martin,
    Yes I saw that also...hmmm. I can only say that i've had no probs using bin/cues and Nero from DVD2SVCD. Not one. Have a go with the CD-RW and post back your trials... perhaps the Denon will work with a certain CD-R media (high reflectivity???) Most will work on CD-RW.
    Cheers
    Studebarc
  8. I tried using TDK silver discs CDRW 80min.
    Nero errors with buffer underrun (the first Ive ever had)
    This is the log
    Windows 2000 5.0
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 12:06:00
    Nero Version: 5.5.6.4
    Recorder: <HP CD-Writer+ 9200> Version: 1.0e - HA 3 TA 6 - 5.5.6.4
    Adapter driver: <AIC78XX> HA 3
    Drive buffer : 4096kB
    Bus Type : default (0) -> SCSI
    CD-ROM: <V386 STEALTH DVD> Version: 1.0h - HA 0 TA 0 - 5.5.6.4
    Adapter driver: <DAEMON> HA 0
    === Scsi-Device-Map ===
    CdRomPeripheral : V386 STEALTH DVD 1.0h Daemon Port 0 ID 0 DMA: ?
    DiskPeripheral : Maxtor 34098H4 atapi Port 1 ID 0 DMA: On
    DiskPeripheral : IOMEGA ZIP 100 atapi Port 2 ID 0 DMA: Off
    CdRomPeripheral : CREATIVE DVD-ROM DVD1242E atapi Port 2 ID 1 DMA: Off
    CdRomPeripheral : HP CD-Writer+ 9200 1.0e aic78xx Port 3 ID 6 DMA: ?
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 61865984 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 511MB (523760kB)
    Free physical memory: 373MB (381964kB)
    Memory in use : 27 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Wizard: Off
    CueSheet
    24.1.2002
    17:42:38 #1 Text 0 File Reader.cpp, Line 117
    Reader running
    17:42:38 #2 Text 0 File Writer.cpp, Line 127
    Writer HP CD-Writer+ 9200 running
    17:42:38 #3 Text 0 File ThreadedTransferInterface.cpp, Line 679
    Setup items (original item values)
    0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
    2 indices, index0 (150) provided
    original CD pos #0 + 535 (535) = #535/0:7.10
    relocatable, CD pos for caching/writing not required/not required, no patch infos
    1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
    4 indices, index0 (150) provided
    original CD pos #0 + 1 + 198010 + 135289 (333300) = #333300/74:4.0
    17:42:39 #4 Text 0 File DlgWaitCD.cpp, Line 194
    Last possible write address on media: 359848 (79:59.73)
    Last address to be written: 333987 (74:15.12)
    17:42:41 #5 Text 0 File DlgWaitCD.cpp, Line 1331
    Recorder: HP CD-Writer+ 9200;
    CDRW code: 00 97 10 00; CD manufacturer unknown
    ATIP Data:
    Special Info [hex] 1: D1 00 C6, 2: 61 0A 00 (LI 97:10.00), 3: 4F 3B 4A (LO 79:59.74)
    Additional Info [hex] 1: 02 4A B0, 2: 5C C6 26, 3: 00 00 00 (invalid)
    17:42:43 #6 Text 0 File ThreadedTransferInterface.cpp, Line 824
    Prepare recorder HP CD-Writer+ 9200 for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x20 Close CD
    Tracks 1 to 2:
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 1611120
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 1611120 1963920 785885520
    17:42:43 #7 Text 0 File ThreadedTransferInterface.cpp, Line 679
    Setup items (after recorder preparation)
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 535 blocks [HP CD-Writer+ 9200 ]
    -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 333300 blocks [HP CD-Writer+ 9200 ]
    17:42:43 #8 Phase 28 File dlgbrnst.cpp, Line 1436
    Speed measurement started
    17:42:43 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1950
    Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
    17:42:43 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1950
    Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #685
    17:44:48 #11 Text 0 File ThreadedTransfer.cpp, Line 219
    all writers idle, stopping conversion
    17:44:48 #12 Phase 29 File dlgbrnst.cpp, Line 1396
    Speed measurement completed: 38.3x (5,745 KB/s)
    17:44:48 #13 Phase 36 File dlgbrnst.cpp, Line 1436
    Burn process started at 4x (600 KB/s)
    17:44:50 #14 Text 0 File ThreadedTransferInterface.cpp, Line 1950
    17:44:50 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1950
    17:44:56 #16 Text 0 File Writer.cpp, Line 304
    17:44:56.169 - HP CD-Writer+ 9200 : Queue again later (Intervall : 100msec)
    17:44:56 #17 SCSI -400 File Cdrdrv.cpp, Line 1407
    SCSI Exec, HA 3, TA 6, LUN 0, buffer 0x08B5F0DC
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x08 (0x03, SCSI_TASTATUS_BUSY)
    Sense Key: 0x00 (KEY_NO_SENSE)
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x2A 0x00 0x00 0x00 0x06 0x44 0x00 0x00 0x1B 0x00
    Sense Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    17:44:56 #18 CDR -400 File Writer.cpp, Line 321
    SCSI Target error
    17:44:56 #19 Text 0 File ThreadedTransfer.cpp, Line 219
    17:44:56 #20 Text 0 File ThreadedTransfer.cpp, Line 213
    conversion idle, stopping reader
    17:45:44 #21 SCSI -1013 File Cdrdrv.cpp, Line 1203
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x03 (KEY_MEDIUM_ERROR)
    Sense Code: 0x0C
    Sense Qual: 0x09
    CDB Data: 0x35 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x06 0x47 0x12
    0x00 0x00 0x00 0x00 0x0C 0x09
    17:45:44 #22 mmc -1013 File WriterStatus.cpp, Line 155
    Buffer underrun
    17:45:44 #23 TRANSFER -24 File WriterStatus.cpp, Line 155
    Could not perform end of Disc At Once
    17:45:44 #24 Phase 38 File dlgbrnst.cpp, Line 1436
    Burn process failed at 4x (600 KB/s)
    17:45:44 #25 Text 0 File Scsicmd.cpp, Line 371
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    17:45:44 #26 SCSI -400 File Cdrdrv.cpp, Line 1203
    Sense Code: 0x00
    Sense Qual: 0x00
    CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00
    Existing drivers:
    File 'Drivers\CDR4VSD.SYS': Ver=2.5 (073), size=72032 bytes, created 23/01/2002 22:45:58
    File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 12:06:00
    File 'WNASPINT.DLL': Ver=V1.13, size=67584 bytes, created 21/09/2001 00:00:00
  9. I think it may be the bin file at fault. I extracted the mpeg back from it and no player could open it (saying corrupted).
    I tried dvd2svcd again on a different film and it stopped at 100% of CCE encoding the vaf file.
    I think I have some issues there...
    QLD Ozwegia
    Yo Martin,
    I think there is a patch for CCE 2.5 around this site somewhere which fixes file size mismatch crashes in CCE. That may be the problem. I use the patch and encounter no more CCE crashes. Search the posts for CCE 2.5 patch and maybe that could cure it. Hope that helps.
    Cheers
    Studebarc
