Can someone please teach me how to backup a HHD using Acronis True Image? I've been lookin for a guides on "how to" but can't find it, preferebly with pictures would be nice. I'm more of a visual learner but if it's impossible then just text would be ok.
I have a laptop and would like to back it up in case it messes up in the future but i read that you need an external hhd in order to back up? Really, it's so confusing. please help.
You can DL this guide from Acronis. It's in PDF format, about 3 MB. http://us1.download.acronis.com/pdf/TrueImage10.0_ug.en.pdf
If you need a PDF reader, I would recommend Foxit. It takes up much less space than the Adobe reader: http://www.foxitsoftware.com/pdf/rd_intro.php
You can back up to about any media. A data DVD would be a good choice as it holds quite a bit. Or an external hard drive would also work. Even CDs. -
If you have access to a desktop than get on eBay a laptop to desktop hard drive adapter for an average of $5.00 shipped and you will be able to clone the drive very easy.
moved to another forum, nobody likes me here... -
open up acronis, at the top select BACKUP (sort of in the top middle you have to run your cursor over it)the "create backup wizard" will open.Hit NEXT and the default is MY COMPUTER(this will let you back up the entire disk.)(if you want to back up files select DATA)and hit NEXT
In the next window select the drive you want to backup by placing a tick in the box next to the drive letter(default is c)and hit NEXT.
The next window asks you where you want to save the data to so select the drive and name your backup
Hit NEXT if its your first backup use the default of FULL BACKUP ARCHIVE,if not then Incremental.
Hit NEXT for default settings then a page for comments will appear,put in what you want and hit NEXT ,now check to make sure the right drives are selected in the screen that appears and if all is well hit PROCEED and leave it to do its job.
When finished reopen the program and below where it says help at the top of the screen there is an icon of a hard drive with a red tick,select this to check the archive(well worth the time)hit NEXT and now navigate to where you put the archive and select it, hit NEXT then PROCEED.
Hope this helps -
Is Backup and Image the same? Because what I meant to ask was how to make an image of my hard drive?
With most backup programs you can do either one. Generally if you 'image' a drive you mean the whole drive, an exact copy. You can also just selectively back up the programs and OS or just selected parts of the disk and not the rest of the stored data to save space. After all, you should already be backing up your data externally.
Chapter three of that PDF file I referenced explains all that better.
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
Image Backup suggestions...
By ranchhand in forum ComputerReplies: 8Last Post: 10th Apr 2010, 19:50 -
Acronis True Image 2010 or NeroBackItUp
By kenmo in forum ComputerReplies: 13Last Post: 19th Nov 2009, 00:55 -
Windows7 & True Image
By beam_brandon in forum ComputerReplies: 1Last Post: 23rd Sep 2009, 06:08 -
Hopefully my final Acronis True Image question.. .
By Denvers Dawgs in forum ComputerReplies: 6Last Post: 26th Jan 2008, 11:34
