I am referring to the cardboard (and sometimes plastic) boxes that hold DVD cases. These are popular with DVD box sets.
Do blank slip cases or slip case kits exist for sale somewhere?
I'd like to make a few.
I market a DVD trilogy and a double set. I use cases that hold multiple DVD's. Then print a sheet to insert under the clear plastic cover. Just like with single DVD's. Printing on a cardboard case is cost prohibitive. I tried for years to print my own VHS sleeves with no luck. DVD is a blessing. You can have an insert printed and look as professional as MGM or anyone else. You can print your own insert. I get cases for multiple DVD's and fitted inserts for printing at:
http://www.polylinecorp.com -
They do , but you might be better off making your own from a simple template .
Refered to as a slip case .
Or digipak would be easier to get a hold of in numbers from almost anywhere . -
I already create color laser inserts for cases, but I want to group multi-disc cases in a larger custom box. Finding good cardboard will be somewhat difficult, but printing and gluing a wrap-around paper to the box will not be that tough. I was mostly curious if a plastic version existed, either plain or with sleeves to hold artwork. If plain, I would use stickers.
I was also looking for some blue-color double Thinpaks, but can't seem to find them for order anywhere. I came across a Chinese plastic company, but that was it (nothing for sale to consumers or small businesses).
Even a cardboard Thinpak case would be great, but you can't find them anywhere.Want my help? Ask here! (not via PM!)
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 02:12 -
canada switching to plastic money
By deadrats in forum Off topicReplies: 5Last Post: 11th Mar 2010, 17:49 -
DVD plastic sleeves
By danielmak in forum MediaReplies: 2Last Post: 8th Mar 2010, 04:51 -
Image Burn SLIP
By wulf109 in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jan 2010, 16:18 -
Where to find non-slip fluid
By CCEncoder in forum Capturing and VCRReplies: 2Last Post: 7th Aug 2007, 12:04
