    Jul 2006
    i have a perfectly working video file however when i use that video in a .avs script the audio becomes out of sync i have tried to delay it however the beginning part becomes okay but the rest of the video messes up.
    please help. thank you.
    Jun 2007
    where did it originally come from? a lot of the time when being converted, emailed or anything like that videos will become out of synch.
    HERE TO HELP
    Ollie.
    Jul 2006
    this is quite weird. i made an .avs script and when i viewed it on my pc it was out of sync so i converted a small sample of it into .mp4 to play on my psp when i was viewing the sample in my psp the audio was perfect. i then converted the whole of the video and it played back fine. so it doesn't matter anymore but thanks anyway.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Being emailed shouldn't have an effect on the audio sync in a video. It's technically a direct byte-for-byte copy of the file, not a conversion. (Yes, you might well lose bits here and there, transferring a video through email. But it shouldn't really have any effect on the audio sync.)
    zinc: More information about your video file and the AVS script would help. If the video is an AVI, load it into GSpot and post a screenshot of the information here (blank out the path and filenames, if you want). If it's a different format, another utility like MediaInfo might help.
    Also, post a copy of the AVS script, if it's not too big. (The same note about file and path names above applies here - edit them out of the script, if you prefer.)
    Jul 2007
    Using Adobe Premiere to edit, exporting to Nero to encode. When I burn it to dvd, the audio starts out fine, but the farther it gets into the program, the more out of sync it gets....What to do?
