Hi,
I use ConvertXToDVD (2.2.1.253) to convert ts files into DVD. Pretty often, while ConvertXToDVD starts conversion, it produces a warning: Error while decoding stream #0.0
The resulting first frames are frozen. It is just a still picture. Further on, everything goes fine.
How to fix the problem?
Also, sometimes the resulting DVD has no audio though ts played with MPC sounded perfectly well. Is it possible to fix?
Thanks.
i've found that most encoders have an easier time if you convert the .ts files to mpg first. try using something like HDTVtoMPEG2.
Thank you!
I tried it already. It work really fine too but I do not know how to handle the resulting MPEG2 files.
I tried Procoder but it starts conversion and crashes after first 10 seconds.
I tried TSUNAMI MPEG Authring but it does not accept such MPEG2 files (high resolution and other stuff).
So, I just do not know what to do with them. I would appreciate your advice. Thanks. -
you might update convertx to the latest 2.2.3 - it is supposed to handle HD ok.
cyberlink's powerdirector is a swiss army knife that can convert from most to most formats, with adjustable audio/video bitrates. it works with hd mpg ok.
procoder you probably need to update to procoder3.
tsunami mpeg, i think was discontinued so you may need to get TMPGEnc 4.0 XPress if you like their products.--
Problems converting video files .MOD to anything
By daka in forum LinuxReplies: 0Last Post: 24th Dec 2010, 13:16 -
Problems converting rm files
By kcahill in forum ffmpegX general discussionReplies: 23Last Post: 7th Dec 2008, 19:03 -
problems converting rmvb files
By Kavelian in forum ffmpegX general discussionReplies: 13Last Post: 15th Jun 2008, 11:58 -
Converting .rmvb files problems
By Gilberts in forum ffmpegX general discussionReplies: 7Last Post: 14th Nov 2007, 17:17 -
Problems converting files using either mencoder or ffmpeg
By krisbee in forum LinuxReplies: 12Last Post: 21st Sep 2007, 07:26
