Hi
Ive got a quite long videoclip, I hope I can get to play. It is an avi file, I shot with my cell phone, but unfortunately it ran out of battery. I have transfered the to my computer, but none of the programs, I've got (both windows and linux) could get anything from it.
Even though recording was uncorrectly ended, it must have recorded something. Can I in any way get that (as video or single frames)? I would really appreciate that.
Thanks in advantage
Super , add video .
Up right , hit other options "o"
Select option in new box "encode for duration"
Hell ... no idea , but it has a bad habit of being able to do almost anything , and get users out of trouble .
I thought in a previous version of super it had encode from frame > to frame ... not there now ... or maybe I was seeing things . -
VLC plays most cellphone video. If like most it is MJPEG, Windows Movie Maker is also likely to play it.
Since it's AVI, you can try seeing if VirtualDub will correct any of the problems. If VirtualDub will load it, it should attempt to fix the AVI's index, and from there, you can also use the "Scan video stream for errors..." command (under the Video menu).
If cameras add ten pounds, why would people want to eat them? -
The super program didn't work - it made an error, I couldn't find a solution to.
The other programs, I've tried is Windows Media Player 9, VLC, Realplayer, Kaffeine, Totem, ACDSee, Avidemux, mediacoder - and maybe others, I've forgotton about.
Well I got some more info about the file through all these progs. It's 23:58 minutes long, xvid 41 mb
Apparantly, the file header/footer thing (i dont know) is missing -
Have you tried any of the repair tools found in the tool section (here)? I haven't tried any of them myself but I guess it's at least worth a try.
In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
Thanks, but unfortunately, none worked.
Isn't it possible just to extract the frame data to image files ?
(I can always sort and recompile those)
WebCam Video corrupted
By igbyslocumb in forum RestorationReplies: 3Last Post: 24th Oct 2011, 20:58 -
Video Becomes corrupted in After Effects
By Foristality in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2011, 04:18 -
Recovering corrupted mini-dv video
By bobogs in forum RestorationReplies: 8Last Post: 16th Aug 2011, 09:45 -
corrupted video file
By stikolyz in forum Video ConversionReplies: 5Last Post: 24th Jan 2010, 02:14 -
MKV Video Being Corrupted by FTP?
By Ast0reth in forum ComputerReplies: 1Last Post: 8th Sep 2009, 09:18
