I did a bit of testing last night to see what (if any) difference a couple of the TMPGEnc settings make.
I was mainly looking at the CQ setting when using aoutomatic VBR.....as of version 2.5 it looks like this is fixed at 65 (bug?) even when u change it in settings it still uses 65.
So, i used one of the version 12's to test.
I did the same clip (taken from devils advocate) and using automatic VBR with CQ settings of 50, 65, and 80.
i burned them to CD and had a look in my standalone.....the result...NO DIFFERENCE.....i spent a long time watching them and replaying them and i couldnt for the life of me spot any difference.
The filesizes were all the same (expected i suppose as bitrate didnt change) and they all took the same time to encode.
one other thing i tried changing was the motion search....i always use high quality (slow).....i tried highest quality(very slow)...and it was indeed very slow....
I didnt see any noticebale difference in quality when playing back....but the filesize was a little smaller?? i have no idea why.
Results 1 to 1 of 1
TMPGEnc Xpress - Clip Settings - No setting for 8:9 PAR
By terpsfan101 in forum Video ConversionReplies: 13Last Post: 17th Jun 2012, 05:28 -
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
TMPGEnc 4 Divx Setting
By Anakin in forum Video ConversionReplies: 2Last Post: 14th Oct 2009, 17:21 -
CL (in Ram) comparison
By Seeker47 in forum ComputerReplies: 3Last Post: 20th Jan 2009, 16:01 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 17:04
