Please Help me ! I need a program to cut the first second of a divx movie avichop wont work. Or something so i can edit the sound in the divx movie becuz its a big click before the movie starts everything else is ok with the movie. I just need a program so i can mute the first second.
Use VirtualDub, with this proc :
Be sure the movie is in AVI, so VDub can handle it.
- Using VDub open the complete movie.
- Now only save the audio as a WAV-file to some location.
- Minimize VDub, but leave the movie opened in VDub.
- Open this WAVe with your prefered WaveEditor.
- Modify the wave, but DON'T cut/delete any parts from it.
- Save the wave.
- Restore VDub.
- Now click at 'video' : "Direct Streaming"
- Also click at 'audio' : WAVE audio (instead of AVI audio). An OpenFile-dialog will apear. Select the WAVE you've just edited.
- Now save the AVI (if necessary - segmented) to a new location.
+ Your new AVI now contains the WAVE you've just edited.
What program can I use to cut segments from a mp4 video?
By alc112 in forum EditingReplies: 9Last Post: 1st Jul 2011, 18:31 -
What program to cut out unwanted sections of DV-AVI for archive
By piperpilot12w in forum EditingReplies: 6Last Post: 30th Aug 2010, 00:52 -
A simple but affective program that i can simply place different avis and cut?
By Mozzy31 in forum EditingReplies: 5Last Post: 10th Feb 2010, 06:56 -
Best program to get clips from factory dvd's into Final Cut Express
By Jabroni4872 in forum MacReplies: 1Last Post: 24th Mar 2009, 21:22 -
What is the best program to split/cut/edit HD videos ??
By ZaYoOoD in forum EditingReplies: 7Last Post: 7th Jun 2008, 15:55
