You don't want one that converts to VOB, you want one that creates a correct DVD structure.
If you want a one click solution, ConvertXtoDVD is about the only one I would trust. If you source is torrents and other downloads, then there is little value in using anything better.
If you have good quality source (and a 700 MB avi file is not good quality source material) then you need to learn how to use all the different tools required to produce a quality outcome.Read my blog here.
Hi-
You're asking for the impossible. You want the best quality, yet at the same time you want something that will do the whole job for you. The best quality isn't found in an all-in-one app. To do it right you first use a dedicated encoder to convert the video to DVD compliant MPEG-2. Then you use a dedicated authoring program to put the pieces together. You can't have it both ways. -
Yep what he said. A very good free video encoder is HC. Audio encoder is Aften with it's Gui. Gfd or dvdauthorgui are both good authoring programs. All listed are free and will give you much better quality and control than any all-in-one app.
Donadagohvi (Cherokee for "Until we meet again")
Convert to DVD (VOB) Highest Quality converter?
By Mark97213 in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2011, 11:47 -
AVI to VOB Converter??
By ChevGirl101 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2009, 16:39 -
The best free avi to vob converter
By mmmipa in forum Authoring (DVD)Replies: 1Last Post: 28th Apr 2008, 18:28 -
needing vts/ vob to avi converter
By sylvester243 in forum Video ConversionReplies: 1Last Post: 11th Oct 2007, 00:42 -
By sylvester243 in forum Video ConversionReplies: 1Last Post: 10th Oct 2007, 23:27
