Had a chance to test out the TmpgencXpress v4 encoder, which supports AVCHD conversion to Mpeg2. Overall, it was a pretty painless method of making a "normal" video. I liked it. If you have the $, it is worth a look.
Used this greyhound dog file as the source (85MB)
https://oncourse.iu.edu/access/content/user/rtknapp/00003.MTS
Here's the result with the $80 TmpgencXpress (45MB 720x480 Mpeg2)
http://www.sendspace.com/file/r0nwhg
Here's the result using the $20 CoreAVC, Avisynth, and the free HC Encoder (45MB 720x480 Mpeg2)
http://www.sendspace.com/file/r7l4q8
Visually, they are going to look slightly different due to different deinterlacers and using the fluxsmooth noise reduction filter in Avisynth.
Xpress Frame 1310
HC_ENC Frame 1310
What are you using to open the AVCHD (with PAFF) file in AVISynth? I have CoreAVC and can open the file in mplayerc but not in AVISynth. DirectShowSource() didn't work. I couldn't open the file in DGIndex to crate a d2v file.
The results look sharp and relatively artifact free but does TMPGEncXpress always deinterlace? -
No, you can turn off deinterlacing if you wish. Just a checkbox.
You absolutely need Haali media splitter installed for Directshowsource to work with CoreAVC. And coreAVC must be v1.2 or later. -
Soopafresh,
I notice you have TMPG 4 XPress - so do I, and I love it for the fact it transcodes, encodes anything - but I'm having hell trying to open the MTS files from my new Panasonic SD1.
You mention 'CoreAVC' and 'Haali media splitter'... Is that something I need installed?
I really appreciate your help! -
CoreAVC is going to be hard to find. Look at v1.81 of Quicktime Alternative.
Just tested out a new app from Elecard which converts your AVCHD file to Standard Def DV. Only $35, but NOT good (yet). The resulting file was smudgy and artifact filled. They're a good company-hopefully the later versions will be better.
AVCHD editing without re-encoding
By cheerful in forum EditingReplies: 1Last Post: 28th Nov 2011, 03:21 -
avchd to mpeg2
By subba in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2011, 10:31 -
Why would anyone want to convert MPEG2 to AVCHD???
By Alphamale1956 in forum Video ConversionReplies: 11Last Post: 9th May 2010, 06:41 -
Time Lapse help, mpeg2 from AVCHD
By cjbrown80 in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2008, 08:26
