Couple of years ago i used to record in divx or xvid because of my small hard drive.
But now it's mpg time @ my house(more stable, less % resource used,higher frame size...all good)
I use WIN DVR3 (intervideo) since it's the most stable software and encoder
*results of mpg encoders tests tend to prove it:
(The higher the Y-PSNR is, the badder the encoder is)
But i always wonder what could be the best settings to record analog source since i'm not 100% digital unfortunately.
For example my settings for GOP and sub gop are: 1,1(that means all images are I frames)
By the way if you know very good encoders, softwares to record in mpg real time,share some infos
All i want is a crisp image,no blocking
The higher psnr the better.
That's an awful pic btw,
and it's not encoders but mpeg2 decoders
gl -
lol i get it all wrong then, well i must admit i wasn't sure at first
but what is sure is that its "decoders" like u said not encoders, so win dvr might be the best still(looking forward for a similar test for encoder)
edit:
what is Y-PSNR?
PSNr is 'Peak signal-to-noise ratio' (source here
it is mentioned: "Typical values for the PSNR in image compression are between 30 and 40 dB" -
That chart appears to be from this paper: http://www.compression.ru/video/codec_comparison/pdf/msu_mpeg_2_decoder_comparison_2006_eng.pdf Look to page 21. The title is:MPEG-2 Video Decoders Comparison
Real-time analog to DV capture - what is the right device to use?
By Serge_KB in forum Capturing and VCRReplies: 16Last Post: 24th Apr 2012, 13:33 -
Real time video capture/display software?
By TheDunk in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2012, 23:16 -
How to capture real-time video from my camcorder onto my PC
By seanhalley in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2011, 05:37 -
Digital8- capture and compress in real time OR shrink result to MKV
By auilani in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 26th Sep 2010, 19:54 -
FlYDS capture REAL-TIME MPEG-2
By goal in forum Capturing and VCRReplies: 3Last Post: 27th Feb 2008, 05:08
