What is generally considered to be the maximum safe bitrate that can be expected to play on virtually all DVD players?
Results 1 to 9 of 9
How long (or short) is a piece of string ?
I have players that will happily play burned discs encoded at 9400 or higher. More conservative players will say as low as 7800. I usually use around 8700 and have never had any issues across a wide range of players.Read my blog here.
This is one of those million dollar questions..
Alot depends on your viewing pleasure. I have found that 4 Mb/s (4000 Kb/s) is acceptable
for a 34" CRT tv however have raised that to at least 5 Mb/s for newer 50" flat screen units.
This is of course to give a good quality end result.
Most commercial dvds appear to encoded at an average bit rate of around 6000 Kb/s and higher
This of course is only my personal findings. -
Your 8700 figure sounds like a good "safe" number. I know the DVD spec says 9848 is the maximum bitrate for an in spec DVD but I'm worried that the $29.95 Walmart special player might tend to choke at 9000+ bit rates.Originally Posted by guns1inger
Seems odd to be concerned about maximum bitrates then talk about junk players.Originally Posted by SCDVD
If you are distributing a DVD that will be viewed on a wide variety of players, it would be a good idea to have them play on all of them. Nothing odd about that.Originally Posted by MysticE
But all DVD players, even the $29.95 ones, are required to play all compliant DVDs. No reason to cripple your DVD because there are a few players out there that might not play it well. But that said, and although I always use a higher max bitrate myself, your 8700kbps figure for the video sounds reasonable. There aren't all that many retail DVDs that use a max video bitrate higher than that.
The spec allows for a total of 10080kbps, with a max of 9800kbps for the video alone:I know the DVD spec says 9848 is the maximum bitrate for an in spec DVD
https://www.videohelp.com/dvd
Problem with Megui Maximum bitrate
By yaoyao0204 in forum Video ConversionReplies: 2Last Post: 17th Feb 2012, 10:57 -
Maximum bitrate for DVD with MKV file
By elmuz in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2011, 11:28 -
Maximum Bitrate
By unity2 in forum Authoring (DVD)Replies: 17Last Post: 24th Jun 2011, 07:25 -
Nerovision maximum bitrate
By whenloverageswild in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2007, 08:40 -
CBR w/Maximum Bitrate = Dissapointing
By jcm0320 in forum Capturing and VCRReplies: 14Last Post: 27th Aug 2007, 21:16
