Hello,
I am from Germany. Seems to be a real expert site here.So maybe someone knows the answer what is wrong:
If I burn DVD ( happens with all kind of DVD material such as alos recorded TV), the program begins to burn but stops suddenly after 2 % .
" Media is possibly bad". Nero test drive prints me different reports. Here is one of a failed DVD burning attempt ( media is not CSS protected)
Would be very kind, if someone here could tell me what might be wrong! Thanks in advance.
From germany
********** Nero Recode **********
Version: 2.5.4.0
cyborg
none
Project type: Copy entire DVD
Compilation name: 1
Target size: DVD5 (2282925)
Burn settings:
Target: HL-DT-ST DVD+-RW GWA4164B
Number of copies: 1
Write speed: 5540 KB/s
Temp folder: E:\Mediendata\temp)
Direct burning: false
Target media: DVD R/RW; DVD R DL; DVD-RAM
Shutdown when finished: false
Advanced Analysis: false
Compress Adaptive: false
15:51:12 File burn_dvdfiles.cpp, Line 238
Compile DVD: init
VTS_01 Title Vobs [8090 vobus] 4014.19MB -> 3803.55MB [R 1.00]
Video: 3218.38MB, extra: 585.17MB
Audio: 3 streams
0. 0. Dolby® Digital 5.1-Kanal Deutsch 210.64MB [enabled]
Subpicture: 1 streams
0. 0. Deutsch 3.30MB [enabled]
15:51:12 File burn_dvdfiles.cpp, Line 1244
Compile DVD: begin copy 1
15:51:12 File NeroRecorderBase.cpp, Line 517
Writing to disc: D
15:51:12 File NeroRecorderBase.cpp, Line 531
Free capacity on disc: 2283093 sectors (2295104)
15:51:12 File burn_dvdfiles.cpp, Line 511
Using previously transcoded files for burning
15:51:12 File NeroRecorderBase.cpp, Line 1392
Burning 8 files with total size of 3988422656 bytes on hard disk
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programme\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14.03.2007 12:43:16
NT-SPTI used
Nero API version: 7.9.6.0
Using interface version: 7.5.0.1
Installed in: C:\Programme\Nero\Nero 7\Core\
Application: Ahead\Nero Recode
Internal Version: 7, 9, 6, 0
Recorder: <HL-DT-ST DVD+-RW GWA4164B>Version: E113 - HA 1 TA 0 - 7.9.6.0
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVD+-RW GWA4164B atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp DVD-ROM TS-H352A atapi Port 0 ID 1 DMA: On
DiskPeripheral : WDC WD1600JS-75NCB1 atapi Port 1 ID 0 DMA: On
DiskPeripheral : SAMSUNG HD403LJ atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
HL-DT-ST DVD+-RW GWA4164B L: CdRom0
TSSTcorp DVD-ROM TS-H352A M: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1046620kB)
Free physical memory: 593MB (607264kB)
Memory in use : 41
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
18.6.2007
NeroAPI
15:51:12 #1 Phase 112 File APIProgress.cpp, Line 285
DVD-Video files reallocation started
15:51:13 #2 Phase 114 File APIProgress.cpp, Line 285
DVD-Video files reallocation completed (no file modified)
15:51:13 #3 Phase 111 File APIProgress.cpp, Line 285
DVD-Video files sorted
15:51:13 #4 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
15:51:13 #5 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
15:51:13 #6 ISO9660GEN -11 File Geniso.cpp, Line 3343
15:51:13 #7 Text 0 File Burncd.cpp, Line 3508
Turn on Disc-At-Once, using DVD media
15:51:13 #8 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1948015 (432:53.40, 3804MB)
15:51:13 #9 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
15:51:13 #10 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: HL-DT-ST DVD+-RW GWA4164B, Media type: DVD+R
Disc Manufacturer ID: SONY, Media Type ID: D21, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
15:51:13 #11 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
15:51:13 #12 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1948016 (1948016) = #1948016/432:53.41
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1948016 blocks [L: HL-DT-ST DVD+-RW GWA4164B]
15:51:13 #13 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [L: HL-DT-ST DVD+-RW GWA4164B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3989536768, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 1948016 | 0 | 0x00
1948016 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
15:51:13 #14 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
15:51:13 #15 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-No, small files-Yes (<32KB)
15:51:13 #16 Phase 24 File APIProgress.cpp, Line 285
Caching of files started
15:51:13 #17 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
15:51:13 #18 Phase 25 File APIProgress.cpp, Line 285
Caching of files completed
15:51:13 #19 Phase 36 File APIProgress.cpp, Line 285
Burn process started at 4x (5.540 KB/s)
15:51:13 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:51:13 #21 Text 0 File Cdrdrv.cpp, Line 9869
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: SONY....
Media type ID: D21
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 53 4F 4E 59 00 - 00 00 00 44 32 31 00 38 ...SONY....D21.8
23 54 37 14 00 28 6E 00 - 80 69 17 19 0C 0C 0A 0B #T7..(n..i......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
15:51:13 #22 Text 0 File DVDPlusRW.cpp, Line 675
Start write address at LBA 0
DVD high compatibility mode: Yes
15:51:13 #23 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
15:51:45 #24 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x80
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0E 00 00 00 00 0C 80
Buffer x190a0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
15:51:45 #25 CDR -1135 File Writer.cpp, Line 303
Write error
15:51:45 #26 Phase 127 File APIProgress.cpp, Line 285
Generating DVD high compatibility borders
15:51:46 #27 Text 0 File DVDPlusRW.cpp, Line 935
EndDAO: Last written address 0
15:51:46 #28 Phase 129 File APIProgress.cpp, Line 285
Generating DVD borders completed successfully
15:51:46 #29 Phase 38 File APIProgress.cpp, Line 285
Burn process failed at 4x (5.540 KB/s)
15:52:08 #30 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
15:52:15 #31 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
15:52:15 #32 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.70a, size=20176 bytes, created 22.04.2005 02:14:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
15:52:17 File NeroRecorderBase.cpp, Line 1198
Burn failed (3)
15:52:17 File burn_dvdfiles.cpp, Line 308
Compile DVD: exit
Results 1 to 10 of 10
First thing, edit your post and take out the serial number from Nero. Stupid that Nero still does this, but it does.
Second, process of elimination to determine the cause. The most likely causes, in no particular order, are
1. Software
2. Burner going bad
3. Burner compatibility with media
4 Something else
Start by using Imgburn to burn the results. Just let recode write to your HDD, then use Imgburn in build mode, select the video_ts folder, and burn a DVD.
If this fails, try a different brand of blank disc. The error message seems to usually be associated with media problems. If you have recently started buying a different brand or faster blanks, that may be the cause.Read my blog here.
standalone, please do not double post. One post per subject is enough.
I would suspect a DVD media problem first myself. You can look up that media to the left in DVD Media: https://www.videohelp.com/dvdmedia?dvdmediasearch=&dvdmediadvdridsearch=d21&type=11&siz...+or+List+Media Or look at: http://www.digitalfaq.com/media/ for more info.
Other than that, I would go with guns1inger's recommendations.
And welcome to our forums.
Moderator redwudz -
thanks- I thought as well about, the burner is going bad.
So I will contact my Hell distributor.
what is about the ASPI Driver by Nero, resp about to replace that aspi with another one - f.i. from adaptec...
(Aspi drivers control the burning) -
I forgot to mention, that my burner is not an HD Burner or a blue ray one . Its just a normal, red light laser drive. I bought the whole set about 1year ago.
Some burning software like Nero provides HD support. So what is about if there is no adequate hardware?
In Germany, a journal recently published, they had tested different blancs from different brands and stated, that up to a half of the blancs simply dont work, due to production changes
In your test, almost only Philips ( i have never tried yet) had good burning results.
I could not find related topics here because the headers are not clear enough- f. I. " Burning problems".
So I will have to check them out again.
sorry that my English is not that perfect.
Thanks again- thats enough for the moment. However -as I am working quite a lot with video or docus,I think I will find some good information here -
Standalone,
Since your English is so good...I would try another burning program first just to be sure. ImgBurn (Image Burn) can easily do what you want since your disc is not copy protected...and it is free. It might even be available in "Deutsch" too.
Prassi Ones is also a VERY good program....es ist nicht kostenlos...but it has a 30 day free trial with full functions. -
Hello, again,
I was talking with the German Dell support, whether the burner probably could be gone bad. Of course Dell has good support and would even exchange the burner for free with the 2 years warranty.
I had before replaced the ASPI driver with same results
I made two burnings with another brand of blanc disc- the first one I used after installing the programs.
It worked again and I could make with that brand one data and one DVD disc that can be played in an external DVD player.
Other users reported ( with the same program- Nero7) to have succesfully used the brand ( Sony DVD+R) that does not work on my PC while they could not burn that ( German: Tevion- Memorex- same type) type that works on my PC.
As that brand or types that works on mine, was that first brand I used after recently formating my hard drive, I believe know that this all is a problem with any driver. (
The SONY discs seem to be okay- so the test I made with them with several programs like nero.
I contacted Sony Europe to ask what is going wrong and just got an immideate answer, I should send the blancs to an expert in Austria.
I just dont believe that something is wrong with the blanc disc themselves So it will need some mor time to find the solution. 8) Cheers!
Might need better firmware.
Maybe too obvious a question... might even have been stated and I missed it -
But does the burner work at all for creating other discs? Can you make data DVDs, CDs of any kind, DVD videos converted from AVIs, etc? Have you tried other media, including any RWs you have around?
That would be the first step to seeing at least if it is a/ the burner, b/ the media...-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
I use Pioneer DVD burners.
I had a 107D which after only about 13 months would read DVds but no longer write them. Was a burner problem. Due to failing laser or dirt or dust on the laser. Not sure but they are cheap so I threw it away and got another one 110D Pioneer.
I use Nero software. never have any problems with it. trying reinstalling Nero and burn more slowly at 4x
Samsung SH-S203N SATA DVD Burner stops responding during burns?
By 1wheelken in forum DVD & Blu-ray WritersReplies: 84Last Post: 24th Aug 2009, 13:30 -
What makes a NEC3500 dvd burner stops reading burned cd's
By joy in forum ComputerReplies: 8Last Post: 1st Dec 2008, 16:19 -
Burning Stops at about 23% ?
By dagerousdave in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Aug 2007, 12:29 -
burning dvds without dvd burner??
By lordscrubba in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 09:19
