  1. When using DVD Decrypter to rip a dvd, is there anyway to keep that "Possible RCE Protection Found" message from coming up? All my discs I rip are R1 so is there some way to tell dvd decrypter to keep that setting and use it for all discs?
    Nickolas
  2. I don't know if this is it but in Tools -> Settings... -> General there are several region related warning options.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    RCE isn't on all discs (and doesn't seem to have been used much, if at all outside the US). I don't believe there is a single answer you can pre-set. You just have to answer when it asks.
    Read my blog here.
