Hi,
I have got a HDTV backup. It is a ts file (4.3 GB). I play such files with MPC but this one is strange. When I try to open it with MPC, there is audio but no picture, just a black screen.
Actually it is already the second file with such a glitch. What's the problem with it? How to fix the problem?
Thank you!
	Maybe a ts with h264 and then you need a h264 codec like coreavc or ffdshow. Or try play with VLC Media Player.
	Thank you, Baldrick! I will try both options. Actually I've got ffdshow but it might happen the option is not set up.
 Is there any difference between coreavc or ffdshow or one of the two would be OK? Thanx.
 I checked my ffdshow. It has H.264 set up.
 I have installed VLC player but it does not help.
 I have installed CoreAVC but no luck too.
 Any ideas, please? Thanks!
	In Media Player, under Options, Performance, try reducing the Video Acceleration from Full to Medium.
	I'm not familiar with the Classic version. Try the embedded version of Media Player. For example, I have v9.
	Windows Media Player gets an error and shuts down every time I try to open a ts file in it. It is 9 too. No luck again.
	Try changing the "performance" setting in Windows Media Player and when that's done, play the file in MPC.
  avstodvd, picture but no audio????HELPBy longy67 in forum Authoring (DVD)Replies: 8Last Post: 28th Aug 2010, 14:26
  Audio but no picture, please helpBy DaneClark in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2010, 17:19
  Audio not in sync with PictureBy runaround in forum Video ConversionReplies: 1Last Post: 21st Jan 2010, 11:09
  DVP5990 Best Picture/Audio Settings?By avkhatri in forum DVD & Blu-ray PlayersReplies: 7Last Post: 18th Feb 2009, 14:47
  DVD Help (regarding audio and picture)By nldnboi in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2007, 08:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
