Anyone know exactly how this works? And if files can be transfered to.from linux that is. Looks very interesting.
LaCie Silverscreen media server
Linux user
That appears to be an external USB powered hard drive, with a additional video driver and video outputs. Most likely any computer that has a USB output should work with it. But you might ask LaCie, but I didn't see where you had to install any programing in the computer to transfer files to the unit. You could DL the PDF format manual from LaCie for more info: http://www.lacie.com/download/manual/silverscreen_en.pdf
EDIT: Here's one review from 2005: http://reviews.cnet.com/portable-video-players-pvps/lacie-silverscreen-40gb/4505-6499_...-31256889.html I see the price for the 40GB model direct from LaCie is about $80US. -
The product you mention supports NTFS, FAT 32, HFS Plus. So if you want to attach it to Linux desktop, my answer would be yes, but you would be better off formatting the disk in fat32 rather than NTFS, as the NTFS drivers are not mature enough on linux.
-GGR -
Thank you appreciate the info.
Ntfs-3g is quite reliable on my dual booting system however it is as you say for fat, especially if plug n play is important as it is for me.Linux user
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
How to quickly split M2TS files just like AVI Splitter works with AVI files
By hoovey1969 in forum EditingReplies: 1Last Post: 30th Nov 2009, 23:42 -
Combing in AVI files when transfered from camera to PC
By ChuckvB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th May 2009, 08:03 -
Vdub Clean up on fuzzy videos transfered to dvd
By Konfusion in forum RestorationReplies: 10Last Post: 16th May 2009, 12:07 -
Adding cover art to WMV to be transfered to the Zune
By MC Rodimus in forum Portable VideoReplies: 3Last Post: 3rd Mar 2009, 00:43
