    Apr 2006
    I tried using this freeware utility to do my AVI to MPEG-2 convertion. I have HC encoder installed (not running).
    I followed the step instructions but at the end the log reveals an error and I no see the MPEG file created, just a couple others including a AC3 file which is about 170MB only (my AVI is about 12GB).
    Here's what I saw in the log, there's gotta be something I'm missing or not understanding:
    [11:37:52 AM] AVI2DVD Started !
    [11:38:12 AM] Type mode : Avi Input
    [11:38:12 AM] Output : Dvd
    [11:38:12 AM] Encoder Selected : HCEnc
    [11:38:12 AM] Start demuxing the AudioStream No.1 ...
    [11:48:14 AM] Demuxing of the selected audio finished
    successfully ! [C:\Documents and
    Settings\VA001PU\Desktop\Vacation
    2006\Avi2dvd_temp\Extracted_Audio.wav 465638962
    Bytes]
    [11:48:14 AM] Audio extracted renamed successfully !
    [C:\Documents and Settings\VA001PU\Desktop\Vacation
    2006\Avi2dvd_temp\Fixed_Audio01.wav 465638962
    Bytes]
    [11:48:14 AM] Starts Wav->Ac3 convertion ...
    [11:54:11 AM] Audio converted in Ac3 successfully !
    2006\Avi2dvd_temp\AudioStream 1 WAV 2CH.ac3
    174614016 Bytes]
    [11:54:11 AM] Start creating avisynth script ...
    [11:54:11 AM] Avisynth script created successfully !
    2006\Avi2dvd_temp\Avisynth_Script_File.avs 200 Bytes]
    [11:54:12 AM] Bitrate used : 7616 Kbpps
    [11:54:12 AM] Start video encoding ...
    [11:54:27 AM] Video encoded successfully ! [C:\Documents
    2006\Avi2dvd_temp\Encoded_Video.m2v -1 Bytes]
    [11:54:27 AM] Job NOT Done. There are warnings ... Find
    at the log file the 0 byte generated file to focus where
    exactly the problem appears
    USA
    Have you tried what the program suggests?
    I haven't used Avi2DVD, but you might try opening the AVS file that was created in notepad and see what it says.
    Was that a DV AVI file you were converting?
    Apr 2006
    yeah, a DV AVI file. When I tried loading the file last night the program gave like an error (was late and did not write it down) and it said that the AVI file had to re-convert into AVI again or something like that. The process actually created another AVI file, which is then the one I am trying to encode with the utility.
    The newly created AVI plays as the original one in media player.
    Apr 2006
    This is the contents of the avs file:
    # Avisynth Script Made By Avi2Dvd
    AviSource("C:\Documents and Settings\VA001PU\Desktop\Vacation 2006\1DaysysTest.avi", false)
    ConvertToYV12()
    LanczosResize(720,428,0.0,0.6)
    AddBorders(0,26,0,26)
