Hello,
Here is a little background on my problem. I had WinDVD Creator 2 bundled on my HP and used it without problem for nearly 2 years. Well, recently, after having to do a system recovery and had to reinstall everything i received an error with Intervideo WinDVD Creator 2 that stated:
"Cannot import ....../.avi. It is unsupported in this version".
* It gives this error now whenever I try to add a .avi video file.
* .mpg seems to be working fine.
I thought it might have been some kind of update that Creator 2 was no longer working so because of the success and ease of use i have had with it in the past 2 years i decided to purchase windvd creator 3 for the $50.
Well, the free trial worked fine and then when I purchased it the 1st burn worked fine. Unfortunately, i'm now stuck with the same problem as the message is reappearing again.Do any of you know what would be the cause of this? Would it be some kind of codec problem? I have DivX and Xvid codecs and they play in realplayer (but not in Windows Media Player for some reason)
I'm truly saddened at the performance lately of this because I use this mainly for burning my .avi and now I just spent $50 to see the exact same error message.
Any help would be truly appreciated. I've gone to Intervideo for help but they haven't even responded to my question and it's been a week. I went to their forums looking for help and again no help, not even a reply. This is pretty much my last chance.![]()
Maybe the codecs are corrupted? Have you tried dropping one of the video files in Gspot 2.70? That will tell you if your codecs are installed. And you can also 'render' the files there to see which codecs and steps it uses to play them. WMP has problems at times, so I wouldn't use it as a reference on whether a file will play. You could also try uninstalling the codecs, then re-install them. Sometimes that re-registers them.
And the 'AVI' designation is about as much info as saying 'video'. There many, many codecs that could loosely be called 'AVI'. Although I'm guessing you mean MPEG-4 as in Xvid or Divx.
Or it may be a problem with the file itself. You might try opening one in VirtualDub Mod, then re-save it with Direct stream copy and see if it works then. If that fails, re-encode it there with full processing and see if that works.
Others here may have some better suggestions.
And welcome to our forums.
Thank you for the reply. I did manage to get ahold of gspot and i put one of my .avi's into it and it does say that for both audio and video that the codecs are installed. For this particular .avi it looks like the audio codec is listed as: "0x0055 MPEG-1 Layer 3" and the video codec is "XviD 1.2 SMP". So you are right these are definitely xvids or divx. Should I try to re-install these or are these codecs outdated in performance with WinDVD Creator?Originally Posted by redwudz
I also have virtual dub (it has come handy in the past from putting 2 movies together), anyways, I tried the direct stream copy and creator still would not accept it. So then i tried the full process with the same result. Again, thanks for the suggestion.Or it may be a problem with the file itself. You might try opening one in VirtualDub Mod, then re-save it with Direct stream copy and see if it works then. If that fails, re-encode it there with full processing and see if that works.
I keep leaning towards the fact that this must be some kind of codec problem? But if i'm able to view the video files on my computer why wouldn't intervideo accept them as video files? I know .avi's are supported and fortunately, i'm not having this problem with mpeg format video files, but something is missing. Should I go ahead and try and re-install the codecs? Thanks again in advance....
edit - I just looked up my currently installed codecs and they are:
DivX 6.6.1
AC3Filter 1.45 (i think i needed this for some kind of audio)
Xvid 1.1
any suggestions on these? should i re-install or get different ones.... -
just to give you guys an update I STILL haven't been able to find a solution to this problem. I tried getting the newest codecs available, reinstalling windvd creator 3, etc. etc. and still no solution. Program will take .mpgs but not .avi....
I'm at a complete loss here......does ANYONE have any ideas? The following is a list of all my installed filters and codecs using GSpot v.270a maybe you guys can see the problem better than i can.
VFW CVID Cinepak Codec by Radius vidc.cvid 0x00200000 quartz.dll --> iccvid.dll
VFW DIVX DivX® 6.6.1 Codec (1 Logical CPU) vidc.divx 0x00200000 quartz.dll --> DivX.dll
VFW I420 Intel 4:2:0 Video V2.50 vidc.i420 0x00200000 quartz.dll --> msh263.drv
VFW IV32 Intel Indeo(R) Video R3.2 vidc.iv32 0x00200000 quartz.dll --> ir32_32.dll
VFW IV41 Intel Indeo® Video 4.5 vidc.iv41 0x00200000 quartz.dll --> ir41_32.ax
VFW IV50 Indeo® video 5.10 vidc.iv50 0x00200000 quartz.dll --> ir50_32.dll
VFW IYUV Intel IYUV codec vidc.iyuv 0x00200000 quartz.dll --> iyuv_32.dll
VFW LEAD LEAD MCMP/MJPEG Codec (VFW) vidc.lead 0x00200000 quartz.dll --> LCODCCMP.DLL
VFW M261 Microsoft H.261 Video Codec vidc.m261 0x00200000 quartz.dll --> msh261.drv
VFW M263 Microsoft H.263 Video Codec vidc.m263 0x00200000 quartz.dll --> msh263.drv
VFW MRLE Microsoft RLE vidc.mrle 0x00200000 quartz.dll --> msrle32.dll
VFW MSVC Microsoft Video 1 vidc.msvc 0x00200000 quartz.dll --> msvidc32.dll
VFW YV12 DivX® 6.6.1 YV12 Decoder vidc.yv12 0x00200000 quartz.dll --> DivX.dll
REND ScriptCommand Internal Script Command Renderer {48025243-2D39-11CE-875D-00608CB78066} 0x00800001 quartz.dll
REND Video Video Renderer {6BC1CFFA-8FC1-4261-AC22-CFB4CC38DB50} 0x00800001 quartz.dll
REND Midi Default MidiOut Device {07B65360-C445-11CE-AFDE-00AA006C14F4} 0x00800000 quartz.dll
REND PCM Default DirectSound Device {79376820-07D0-11CF-A24D-0020AFD79767} 0x00800000 quartz.dll
REND Stream .RAM file Parser {A98C8400-4181-11D1-A520-00A0D10129C0} 0x00600000 wmpasf.dll
REND Stream ASX v.2 file Parser {640999A1-A946-11D0-A520-000000000000} 0x00600000 wmpasf.dll
REND Video Video Renderer {70E102B0-5556-11CE-97C0-00AA0055595A} 0x00400000 quartz.dll
REND Null Renderer {C1F400A4-3F08-11D3-9F0B-006008039E37} 0x00200000 qedit.dll
REND Midi Microsoft GS Wavetable SW Synth {07B65360-C445-11CE-AFDE-00AA006C14F4} 0x00200000 quartz.dll
REND Audio Realtek HD Audio rear output {E30629D1-27E5-11CE-875D-00608CB78066} 0x00200000 quartz.dll
REND Audio Default WaveOut Device {E30629D1-27E5-11CE-875D-00608CB78066} 0x00200000 quartz.dll
REND PCM DirectSound: Realtek HD Audio rear output {79376820-07D0-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
REND Video Full Screen Renderer {07167665-5011-11CF-BF33-00AA0055595A} 0x00200000 quartz.dll
REND Video Video Mixing Renderer 9 {51B4ABF3-748F-4E3B-A276-C828330E926A} 0x00200000 quartz.dll
DSH XVID DivX Decoder Filter {78766964-0000-0010-8000-00AA00389B71} 0xff800000 divxdec.ax
DSH MPEG1Packet MPEG Video Decoder {FEB50740-7BEF-11CE-9BD9-0000E202599C} 0x40000001 quartz.dll
DSH MPEG1Packet MPEG Audio Decoder {4A2286E0-7BEF-11CE-9BD9-0000E202599C} 0x03680001 quartz.dll
DSH FmtTag: 0x0055 MPEG Layer-3 Decoder {38BE3000-DBF4-11D0-860E-00A024CFEF6D} 0x00810000 l3codecx.ax
DSH WMAudioV2 Windows Media Audio Decoder {22E24591-49D0-11D2-BB50-006008320064} 0x00800001 msadds32.ax
DSH ACELPnet ACELP.net Sipro Lab Audio Decoder {4009F700-AEBA-11D1-8344-00C04FB92EB7} 0x00800001 acelpdec.ax
DSH Video LEAD MCMP/MJPEG Decoder {78D80081-F388-11D3-9161-00105A07EA40} 0x00800000 LCODCCMP.DLL
DSH MPG4 Microsoft MPEG-4 Video Decompressor {82CCD3E0-F71A-11D0-9FE5-00609778EA66} 0x00800000 mpg4ds32.ax
DSH DVSD DV Video Decoder {B1B77C00-C3E4-11CF-AF79-00AA00B67A42} 0x00800000 qdv.dll
DSH MSS1 Microsoft Screen Video Decompressor {3301A7C4-0A8D-11D4-914D-00C04F610D24} 0x00800000 msscds32.ax
DSH WMV1 Windows Media Video Decoder {4FACBBA1-FFD8-4CD7-8228-61E2F65CB1AE} 0x00800000 wmvds32.ax
DSH WMV2 Windows Media Video Decoder {521FB373-7654-49F2-BDB1-0C6E6660714F} 0x00800000 wmv8ds32.ax
DSH Video InterVideo MPEG4 Video Decoder {604C9C22-F099-4482-A416-A02DC1FB264C} 0x00800000 MP4VDEC.ax
DSH DOLBY_AC3 InterVideo Audio Decoder {7E2E0DC1-31FD-11D2-9C21-00104B3801F6} 0x00700000 iviaudio.ax
DSH MPEG2_VIDEO InterVideo Video Decoder {0246CA20-776D-11D2-8010-00104B9B8592} 0x00700000 IVIVIDEO.ax
DSH IV41 Indeo® video 4.4 Decompression Filter {31345649-0000-0010-8000-00AA00389B71} 0x00640000 ir41_32.ax
DSH IV50 Indeo® video 5.10 Decompression Filter {30355649-0000-0010-8000-00AA00389B71} 0x00640000 ir50_32.dll
DSH MJPG AVI Draw {A888DF60-1E90-11CF-AC98-00AA004C0FA9} 0x00600064 quartz.dll
DSH AUXLine21Data Line 21 Decoder 2 {E4206432-01A1-4BEE-B3E1-3702C8EDC574} 0x00600002 quartz.dll
DSH MPEG1System MainConcept MPEG Splitter {2BE4D120-6F2E-4B3A-B0BD-E880917238DC} 0x00600002 mcspmpeg.ax
DSH Avi DivX Demux {85516702-9C45-4A9C-861B-BC4492D355DC} 0x00600000 DivXMedia.ax
DSH Audio Decrypt/Tag {C4C4C4F2-0049-4E2B-98FB-9537F6CE516D} 0x00600000 encdec.dll
DSH VPVideo Video Port Manager {6F26A6CD-967B-47FD-874A-7AED2C9D25A2} 0x00600000 quartz.dll
DSH TELETEXT WST Decoder {70BC06E0-5666-11D3-A184-00105AEF9F33} 0x00600000 wstdecod.dll
DSH VPVBI VBI Surface Allocator {814B9800-1C88-11D1-BAD9-00609744111A} 0x00600000 vbisurf.ax
DSH MPEG2_TRANSPORT MPEG-2 Demultiplexer {AFB6C280-2C41-11D3-8A60-0000F81E0E4A} 0x00600000 mpg2splt.ax
DSH WM9_ASF_Undocumented ASF DIB Handler {B9D1F320-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH ASF_Audio_Media ASF ACM Handler {B9D1F321-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH ASF_Video_Media ASF ICM Handler {B9D1F322-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH WM9_ASF_Undocumented ASF URL Handler {B9D1F323-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH ASF_JFIF_Media ASF JPEG Handler {B9D1F324-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH ASF_Degradable_JPEG_Media ASF DJPEG Handler {B9D1F325-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH LMRT ASF embedded stuff Handler {B9D1F32E-C401-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH DXRE DivX Subtitle Decoder {BA11F969-397A-4146-AC96-236C3D76711D} 0x00600000 DivXMedia.ax
DSH QTMovie QuickTime Movie Parser {D51BD5A0-7548-11CF-A520-0080C77EF58A} 0x00600000 quartz.dll
DSH Stream RealMedia Splitter {E21BE468-5C18-43EB-B0CC-DB93A847D769} 0x00600000 RealMediaSplitter.ax
DSH QTRpza QT Decompressor {FDFE9681-74A3-11D0-AFA7-00AA00B67A42} 0x00600000 quartz.dll
DSH PCM Intervideo AMR Encoder {FF7667A9-586B-499A-B72A-F31445004000} 0x00600000 AmrEnc.ax
DSH Avi AVI Splitter {1B544C20-FD0B-11CE-8C63-00AA0044B51E} 0x00600000 quartz.dll
DSH DOLBY_AC3 AC3 Parser Filter {280A3020-86CF-11D1-ABE6-00A0C905F375} 0x00600000 mpg2splt.ax
DSH MPEG1Packet MainConcept MPEG Audio Decoder {2BE4D130-6F2E-4B3A-B0BD-E880917238DC} 0x00600000 mcdsmpeg.ax
DSH MPEG1Packet MainConcept MPEG Video Decoder {2BE4D140-6F2E-4B3A-B0BD-E880917238DC} 0x00600000 mcdsmpeg.ax
DSH MJPG MJPEG Decompressor {301056D0-6DFF-11D2-9EEB-006008039E37} 0x00600000 quartz.dll
DSH WM9_ASF_Undocumented Windows Media Multiplexer {63F8AA94-E2B9-11D0-ADF6-00C04FB66DAD} 0x00600000 wmpasf.dll
DSH Stream ASX file Parser {640999A0-A946-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH Stream NSC file Parser {640999A2-A946-11D0-A520-000000000000} 0x00600000 wmpasf.dll
DSH Audio ACM Wrapper {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00600000 quartz.dll
DSH AUXLine21Data Line 21 Decoder {6E8D4A20-310C-11D0-B79A-00AA003767A7} 0x00600000 qdvd.dll
DSH MPEG1System MPEG-I Stream Splitter {336475D0-942A-11CE-A870-00AA002FEAB5} 0x00600000 quartz.dll
DSH DVSD DV Splitter {4EB31670-9FC6-11CF-AF6E-00AA00B67A42} 0x00600000 qdv.dll
DSH MPEG2_PROGRAM MPEG-2 Splitter {3AE86B20-7BE8-11D1-ABE6-00A0C905F375} 0x005fffff mpg2splt.ax
DSH PCM Indeo® audio software {B4CA2970-DD2B-11D0-9DFA-00AA00AF3494} 0x00500000 iac25_32.ax
DSH RGB8 Color Space Converter {1643E180-90F5-11CE-97D5-00AA0055595A} 0x00400001 quartz.dll
DSH Video Windows Media Update Filter {B6353564-96C4-11D2-8DDB-006097C9A2B2} 0x00400000 wmpasf.dll
DSH Stream XML Playlist {D51BD5AE-7548-11CF-A520-0080C77EF58A} 0x00400000 wmpasf.dll
DSH 14_4 RealAudio Decoder {941A4793-A705-4312-8DFC-C11CA05F397E} 0x00400000 RealMediaSplitter.ax
DSH Video Overlay Mixer2 {A0025E90-E45B-11D1-ABE9-00A0C905F375} 0x00400000 qdvd.dll
DSH WAVE Wave Parser {D51BD5A1-7548-11CF-A520-0080C77EF58A} 0x00400000 quartz.dll
DSH Midi MIDI Parser {D51BD5A2-7548-11CF-A520-0080C77EF58A} 0x00400000 quartz.dll
DSH Stream Multi-file Parser {D51BD5A3-7548-11CF-A520-0080C77EF58A} 0x00400000 quartz.dll
DSH File File stream renderer {D51BD5A5-7548-11CF-A520-0080C77EF58A} 0x00400000 quartz.dll
DSH RGB8 VGA 16 Color Ditherer {1DA08500-9EDC-11CF-BC10-00AA00AC74F6} 0x00400000 quartz.dll
DSH RV20 RealVideo Decoder {238D0F23-5DC9-45A6-9BE2-666160C324DD} 0x00400000 RealMediaSplitter.ax
DSH Stream SAMI (CC) Parser {33FACFE0-A9BE-11D0-A520-00A0D10129C0} 0x00400000 quartz.dll
DSH Intervideo 3gFileWrite {D93FFF37-E2A3-4F6D-858D-8E4B07CD7B24} 0x00200000 Write3g.ax
DSH RGB24 Essien R&D MPEG Writer Filter v3 {FCBC352A-E3D7-440B-8D25-C41B8EE6CBC6} 0x00200000 mpgfiltr.ax
DSH InterVideo Stream Renderer {6FEE7C7B-94F4-4285-B3E4-C0184065E9B3} 0x00200000 IviStreamRenderer.ax
DSH MPEG2_PES InterVideo DVB DSM-CC Filter {82801A43-E2FE-2ADD-9CA5-502F336ECCC9} 0x00200000 DvbDsmcc.ax
DSH File writer {8596E5F0-0DA5-11D0-BD21-00A0C911CE86} 0x00200000 qcap.dll
DSH DVSD WMT Virtual Renderer {930FD02C-BBE7-4EB9-91CF-FC45CC91E3E6} 0x00200000 wmm2filt.dll
DSH Video muvee Video Analyser {AA478720-468A-41AB-9D97-263B6580FE8C} 0x00200000 mvvanalyse.ax
DSH Audio muvee Music Analyser {AA478722-468A-41AB-9D97-263B6580FE8C} 0x00200000 mvmanalyse.ax
DSH InterVideo Stream Writer {AAD9D04B-4C0F-4149-AD80-828BFF207F48} 0x00200000 StmRite.ax
DSH InterVideo File Writer {D2288805-7D1E-49D4-9934-6D5B3728E155} 0x00200000 IVIwrite.ax
DSH Avi AVI Mux {E2510970-F137-11CE-8B67-00AA00A3F1A6} 0x00200000 qcap.dll
DSH InterVideo Disc Write2 Filter {43C9E2EC-3D64-4154-95FF-193FA177D9A3} 0x00200000 DiscRite.ax
DSH YUY2 InterVideo Video Encoder {317DDB61-870E-11D3-9C32-00104B3801F6} 0x00200000 IVIVENC.ax
DSH YV12 MainConcept MPEG Encoder {2BE4D150-6F2E-4B3A-B0BD-E880917238DC} 0x00200000 mcesmpeg.ax
DSH UYVY InterVideo Pre-scaling Filter {77829DBC-A0CA-4A8C-A509-680A6D6B96CB} 0x00200000 IVIScale.ax
DSH Video WMT Sample Information Filter {7F1232EE-44D7-4494-AB8B-CC61B10E21A5} 0x00200000 wmm2filt.dll
DSH InterVideo DVB Subpicture Filter {82801A43-D6FE-4EDD-9CA5-5020336ECCC9} 0x00200000 DvbSpic.ax
DSH Stream InterVideo Transport to Program Stream {82D03B28-1B7E-4806-B5A6-E6677C5D2CC4} 0x00200000 TrToProg.ax
DSH Video WMT Log Filter {92883667-E95C-443D-AC96-4CACA27BEB6E} 0x00200000 wmm2filt.dll
DSH UYVY InterVideo MPEG4 Video Encoder {A7375B02-8639-45A5-9C03-E2EFA88BF91D} 0x00200000 MP4VENC.ax
DSH Video WMT DirectX Transform Wrapper {AECF5D2E-7A18-4DD2-BDCD-29B6F615B448} 0x00200000 wmm2filt.dll
DSH PCM G.711 Codec {AF7D8180-A8F9-11CF-9A46-00AA00B7DAD1} 0x00200000 g711codc.ax
DSH Video 9x8Resize {BC0D69A8-0923-4EEE-9375-9239F5A38B92} 0x00200000 wmm2filt.dll
DSH Video WIA Stream Snapshot Filter {BC7ACB90-622B-11D2-829D-00C04F8EC183} 0x00200000 wiasf.ax
DSH Video Allocator Fix {C0D076C5-E4C6-4561-8BF4-80DA8DB819D7} 0x00200000 wmm2filt.dll
DSH SampleGrabber {C1F400A0-3F08-11D3-9F0B-006008039E37} 0x00200000 qedit.dll
DSH Video WMT Interlacer {C6CB1FE3-B05E-4F0E-818F-C83ED5A0332F} 0x00200000 wmm2filt.dll
DSH Audio RealPlayer Audio Filter {CEF4D40F-ACA5-40BA-8F3B-161A594A1A39} 0x00200000 rdsf3260.dll
DSH RGB24 Uncompressed Domain Shot Detection Filter {CFFB1FC7-270D-4986-B299-FECF3F0E42DB} 0x00200000 wmm2filt.dll
DSH Correct Corrupted Audio {D39C7090-C9EF-4812-AB17-BA9402873205} 0x00200000 CorrectA.ax
DSH YV12 InterVideo Still Capture {DB080360-01B9-11D4-898C-00A0CC5211EF} 0x00200000 IVIscapt.ax
DSH Video WMT DV Extract {E476CBFF-E229-4524-B6B7-228A3129D1C7} 0x00200000 wmm2filt.dll
DSH InterVideo MpegInspect {EECB9528-5FDD-4593-B7D2-2C99769589CE} 0x00200000 mpginspc.ax
DSH Video WMT Switch Filter {EF105BC3-C064-45F1-AD53-6D8A8578D01B} 0x00200000 wmm2filt.dll
DSH Audio WMT Volume {EFEE43D6-BFE5-44B0-8063-AC3B2966AB2C} 0x00200000 wmm2filt.dll
DSH Video Stretch Video {F44BB2D0-F070-463E-9433-B0CCF3CFD627} 0x00200000 wmm2filt.dll
DSH Video InterVideo DV Pre-Process {F54FF744-9B63-48FE-9C76-1F1F3B7F1BD7} 0x00200000 dvProcs.ax
DSH Infinite Pin Tee Filter {F8388A40-D5BB-11D0-BE5A-0080C706568E} 0x00200000 qcap.dll
DSH Video Indeo® video 4.4 Compression Filter {A2551F60-705F-11CF-A424-00AA003735BE} 0x00200000 ir41_32.ax
DSH PCM InterVideo Audio Encoder {0CD2E140-8D60-11D3-9C32-00104B3801F6} 0x00200000 iviaenc.ax
DSH Audio IAC2 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio IMA ADPCM {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio PCM {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio Microsoft ADPCM {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio ACELP.net {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio DSP Group TrueSpeech(TM) {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio Windows Media Audio V1 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio Windows Media Audio V2 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio GSM 6.10 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio Microsoft G.723.1 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio CCITT A-Law {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio CCITT u-Law {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio MPEG Layer-3 {6A08CF80-0E18-11CF-A24D-0020AFD79767} 0x00200000 quartz.dll
DSH Audio InterVideo Audio Processor {0BEDA08A-C516-4A44-9141-7B2CF28975EA} 0x00200000 ** File Missing: C:\Program Files\InterVideo\Common\Bin\IviAudioProcess.ax
DSH Audio WMT AudioAnalyzer {1CB1623E-BBEC-4E8D-B2DF-DC08C6F4627C} 0x00200000 wmm2filt.dll
DSH Video Indeo® video 5.10 Compression Filter {1F73E9B1-8C3A-11D0-A3BE-00A0C9244436} 0x00200000 ir50_32.dll
DSH Video WMT Format Conversion {2D20D4BB-B47E-4FB7-83BD-E3C2EE250D26} 0x00200000 wmm2filt.dll
DSH Video WMT Black Frame Generator {2EA10031-0033-450E-8072-E27D9E768142} 0x00200000 wmm2filt.dll
DSH MPEG1AudioPayload InterVideo Multiplexer {317DDB63-870E-11D3-9C32-00104B3801F7} 0x00200000 ivimux.ax
DSH MPEG2_PROGRAM InterVideo Demultiplexer {317DDB73-870E-11D3-9C32-00104B3801F7} 0x00200000 IVIdemux.ax
DSH Video muvee HXImage Filter {3E1434A3-1303-4F14-9762-40B97A6C136D} 0x00200000 HXImageFilter.ax
DSH RGB24 Bitmap Generate {4F3E50BD-A9D7-4721-B0E1-00CB42A0A747} 0x00200000 wmm2filt.dll
DSH Video InterVideo VBI Decoder {5708A5D4-5DD4-44E4-A665-604BC2F1E921} 0x00200000 IvVBIDec.ax
DSH Video WMT VIH2 Fix {586FB486-5560-4FF3-96DF-1118C96AF456} 0x00200000 wmm2filt.dll
DSH Video Record Queue {5B4B05EB-1F63-446B-AAD1-E10A34D650E0} 0x00200000 wmm2filt.dll
DSH UYVY InterVideo Down Scale Filter {61B82E90-51CD-464A-8DA8-19AA6AB6C834} 0x00200000 IVIDownS.ax
DSH Video Frame Eater {6C68955E-F965-4249-8E18-F0977B1D2899} 0x00200000 wmm2filt.dll
DSH Video Smart Tee {CC58E280-8AA1-11D1-B3F1-00AA003761C5} 0x00200000 qcap.dll
DSH DVSD InterVideo Stream Buffer Filter {09FE0BA8-B7FA-4D82-8669-C62557470B5B} 0x00200000 SmBuffer.ax
DSH MPEG1System InterVideo Demux {105808AA-413D-4F32-898B-C15457292D55} 0x00200000 IVIdemxx.ax
DSH Avi InterVideo Time Shift {1D349B41-9B67-11D3-B718-00A0CC502E02} 0x00200000 ivits.ax
DSH Video LEAD MCMP/MJPEG Codec {78D80080-F388-11D3-9161-00105A07EA40} 0x00100000 LCODCCMP.DLL
DMO WMVA WMVideo Advanced Decoder DMO {03BE3AC4-84B7-4E0E-A78D-D3524E60395A} 0x00800001 qasf.dll --> wmvadvd.dll
DMO MP4S Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2} 0x00800001 qasf.dll --> mp4sdmod.dll
DMO MSS1 WMV Screen decoder DMO {7BAFB3B1-D8F4-4279-9253-27DA423108DE} 0x00800001 qasf.dll --> wmsdmod.dll
DMO WMV1 WMVideo Decoder DMO {82D353DF-90BD-4382-8BC2-3F6192B76E34} 0x00800001 qasf.dll --> wmvdmod.dll
DMO MP43 Mpeg43 Decoder DMO {CBA9E78B-49A3-49EA-93D4-6BCBA8C4DE07} 0x00800001 qasf.dll --> mp43dmod.dll
DMO MPG4 Mpeg4 Decoder DMO {F371728A-6052-4D47-827C-D039335DFE0A} 0x00800001 qasf.dll --> mpg4dmod.dll
DMO FmtTag: 0x0045 InterVideo G726Dec DMO {0121AE2F-84B3-4A1C-A6F9-255EB81B17F5} 0x00000000 qasf.dll --> G726Dec.dll
DMO FmtTag: 0x0160 WMAudio Decoder DMO {2EEB4ADF-4578-4D10-BCA7-BB955F56320A} 0x00800800 qasf.dll --> wmadmod.dll
DMO WMAudioV9 WMAPro over S/PDIF DMO {5210F8E4-B0BB-47C3-A8D9-7B2282CC79ED} 0x00000000 qasf.dll --> wmadmod.dll
DMO WMSP1 WMSpeech Decoder DMO {874131CB-4ECC-443B-8948-746B89595D20} 0x00000000 qasf.dll --> wmspdmod.dll
ACM FmtTag: 0x0011 IMA ADPCM CODEC for MSACM msacm.imaadpcm 0x00200000 quartz.dll --> imaadp32.acm
ACM FmtTag: 0x0002 Microsoft ADPCM CODEC for MSACM msacm.msadpcm 0x00200000 quartz.dll --> msadp32.acm
ACM FmtTag: 0x0006 Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM msacm.msg711 0x00200000 quartz.dll --> msg711.acm
ACM FmtTag: 0x0007 Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM msacm.msg711 0x00200000 quartz.dll --> msg711.acm
ACM FmtTag: 0x0031 Microsoft GSM 6.10 Audio CODEC for MSACM msacm.msgsm610 0x00200000 quartz.dll --> msgsm32.acm
ACM FmtTag: 0x0022 DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50 msacm.trspch 0x00200000 quartz.dll --> tssoft32.acm
ACM FmtTag: 0x0042 Microsoft G.723.1 CODEC for MSACM msacm.msg723 0x00200000 quartz.dll --> msg723.acm
ACM FmtTag: 0x0160 Windows Media Audio msacm.msaudio1 0x00200000 quartz.dll --> msaud32.acm
ACM WMAudioV2 Windows Media Audio msacm.msaudio1 0x00200000 quartz.dll --> msaud32.acm
ACM ACELPnet Audio codec for MS ACM msacm.sl_anet 0x00200000 quartz.dll --> sl_anet.acm
ACM FmtTag: 0x0402 Indeo® audio software msacm.iac2 0x00200000 quartz.dll --> iac25_32.ax
ACM FmtTag: 0x0055 MPEG Layer-3 Audio Codec for MSACM msacm.l3acm 0x00200000 quartz.dll --> l3codeca.acm
¤ Video AVI Decompressor {CF49D4E0-1115-11CE-B03A-0020AF0BA770} 0x00600000 quartz.dll
It also states that Intervideo audio processor file is missing. Only "problem" file found... could that be it?
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 13:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 19:57 -
My WinDVD creator 2 program won't read it's .wcp files
By Willietom in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2008, 12:21 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 06:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 22:43
