    Jun 2007
    Is there a way to change the dimension of the video?
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Yes, use the Resize filter.
    Buy My Books
    Jun 2007
    Is this already installed with vdub or do i gotta add this on?
  4. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Built in. Go to Video\Filters\Add then select the Resize filter.
    Buy My Books
    Jun 2007
    ok i found it thanks.
    Jun 2007
    Well im having another problem now...im trying to use the x264 codec on vdub and when i go to save avi and such its just doing the audio and not creating a video, its acting as if theres no codec there to use but there is one because i even look at the config on the codec and etc.
