Here's the problem:
I use DU METER to keep an eye on the info that goes to and from the net and It's really neat, but yesterday I noticed that even though I was doing nothing with it, there was a constant flow of 3.2Kbps being downloaded from the net.
The DU METER program told me that information was flowing, but is there another program that will let me know what program is sending/receiving this info?. Like in Task Manager you sort the apps in ascending/descending order if you want to know which one is consuming the most processor / memory...
Any ideas?
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
Will http://www.netlimiter.com/ give you what you're looking for?
It looks like it will work!, I will check it, thanks!!
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
I used it quite a while back to limit the bandwidth on one of those downloading programs... I could set the programs upload to max (which then gave you maximum download) and limit it with NetLimiter.
i think you'll find it's an auto-updater program, like windows update for instance..
hey that looks like a cool app, thanks!Originally Posted by SquirrelDipI am just a worthless liar,
I am just an imbecil
Wireless Printer Sends My Internet For A Loop
By V Bot in forum ComputerReplies: 5Last Post: 20th Jan 2011, 20:57 -
seeing the commands ffmpegX sends to ffmpeg
By cablet in forum ffmpegX general discussionReplies: 1Last Post: 6th Jul 2010, 17:02 -
help with video monitoring
By rogha in forum Newbie / General discussionsReplies: 1Last Post: 3rd Apr 2010, 13:53 -
monitoring problem
By tomwaites in forum MacReplies: 0Last Post: 19th Jan 2010, 19:23 -
Folder monitoring....
By cmatt in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2008, 11:52
