i have a movie file (.avi ) which plays perfectly in my pc with vlc player .. when i BURN it to the CD with nero , then the audio sync is terrible.. what should i do
	Do you burn it as a data file to the CD, or as some kind of video disk format like VCD or SVCD?
 /Mats
	burned it as vcd to watch it on standalone vcd player .. the original file was a dvdrip (legal) !
	Then it's not the actual burning that is the problem area, but the conversion from AVI to mpg1.
 I don't know how many times I've said this, but Nero really is not to be considered for anything but data burning. As a video format converter, it, well, leaves a lot to be desired...
 Most likely your AVI has VBR audio - something that throws most encoders off.
 EazyVCD is rumored as the good choice for oneclick AVI to VCD. I suggest you try that, or head over to the CONVERT section left, look up "AVI to VCD", and start reading!
 Basically, to do it by hand, you need:
 VirtualDub (for AVI preprocessing if needed)
 TMPGEnc (for encoding)
 VCDEasy (for authoring)
 /Mats
	thanks a lot for all the valuable info mats  .. one more thing .. what is the best way to burn a dvdrip to play it on a standalone DVD  Lg 9xxx series player ?? .. one more thing .. what is the best way to burn a dvdrip to play it on a standalone DVD  Lg 9xxx series player ??
	What LG 9xxx? It may play DivX - If so, just burn the AVI as data file to a CD-R or DVD-R. Even Nero can't go wrong with this task, but ImgBurn is the most reliable burner tool available.
 /Mats
  audio sync problem, how to work out progressive audio sync delayBy jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09
  SOLVED:Mpeg2 Video (Movie cilp) to PAL DVD - sync prob using DVDFlick.....By bahjan in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 11:03
  audio sync issues after converting mkv to iso and burning to bd-r/dl disc..By landocass in forum Newbie / General discussionsReplies: 1Last Post: 26th Jul 2010, 16:03
  prob joining VOBs; also sync prob with another movieBy spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32
  audio sync prob dazzle dvc-150 and virtualdubBy zephxiii in forum Capturing and VCRReplies: 5Last Post: 30th Jul 2007, 14:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
