I'm refreshing my collection of old data CDs I've burned over the last several years. I'm consolidating the data files I backed up onto TY DVD+R blanks.
On one el cheapo CD-R I burned in January of 2003 I have almost 5,400 files in 1,800 directories consuming about 640 MB bytes. xcopy copied many files but choked on an error after a while. IsoBuster was able to create an iso image of the disc for me, but there were perhaps a dozen sector read errors where I told it to replace the bad sector data with 0s. I mounted the iso image on a virtual CD-ROM drive in XP SP2 and xcopy from that to the hard disk ran without any errors.
Most of the data is fine. There are html, MS Word, and PDFs that are OK. But I know there are some files that will not be OK because of the sector errors on the CD. I ran into one PDF that would not open and a BMP that Photoshop refused to load. There are undoubtedly other files that are bad.
Is there a tool that will tell me which files were located at specific sector numbers on the CD? Is that information available from the TOC on the disc? If there is I can match the bad sector numbers given to me by IsoBuster and see exactly what I have lost.
Results 1 to 11 of 11
You can use cdcheck for that. download at http://www.kvipu.com/CDCheck/
While this is a little beyond the scope of your specific question, if you're backing up a lot of things and want to be sure you have good copies, you might look into making and storing separate PAR files for your backup discs. You could set up PAR files to let you recover if 5% or 10% (or more if you wish, but it produces bigger files) of your archive is damaged. I read here on these forums about a guy who backups stuff to DVD or CD (I forgot which) and he stores PAR files on another disc to enable him to recover the archive if it gets corrupted. You might want to look into this.
I don't want to come across as too much of a gimp for Ahead software too often, but I'd use Nero CD/DVDSpeed (again
) if you have access to it. There's a handy tab where you can run what is basically a version of Scandisc for optical media... once it's done (assuming it doesn't hang at a bad section
) you'll have a list of files and a judgement on whether they're "good" (read ok first time), "damaged" (read ok eventually, but needed retries), or "bad" (could not be successfully read for some/all of their length). Makes it simple.... you know which ones to get off there immediately at high speed before any other disaster strikes (good), which to get next, letting the drive churn for a while at a slightly lower speed (damaged), and which to break out the big recovery guns for - whitening toothpaste, olive oil, 1x speed, etc! (bad)
Signed, the victim of rubbish, corroding early-days CDR / RW media
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
Thanks for the tips. I'm going to give cdcheck and CD/DVD Speed a try this evening.
I ran into another disc today I burned in 2003 with similar problems. It read 98.5% fine and then started giving read errors. FWIW I have always used whatever "verify after burn" options were available in my burning software, so I am confident the burns were good 4.5 years ago. I should mention there are 6 other discs from the same batch that were readable without any errors at all.
It is scary taking literally tens of thousands of files and trusting them to 1 blank DVD. Too bad there's not a filesystem format for burning that saves redundant error-correcting data natively (like PAR files do) as part of the burn. -
No, but I will since neither Nero nor cdcheck did what I wanted. They go until they encounter a read error, tell me about the file that couldn't be read, and stop. I'd like to know all the files that cannot be read, not just the first one.
I still have the CDs that were giving me trouble. At some point I will toss them and that time is drawing near, so thanks for another suggestion.
UPDATE: While it looks like it might be useful as a preventive measure when you burn new discs, it doesn't do anything new for me except draw a pretty picture. I uninstalled it already. -
This might be too late, but your solution is http://www.imgburn.com/
Use Verify Mode, it'll give you all the bad sectors (not just the first one) and will let you know which file is affected by it. -
Did you try ISOBuster's "Managed" Images (which allows one to use the best rips from multiple drives)? This has greatly improved rips from badly damaged discs for me. IIRC, it is only available to "Pro" use, so you would have to register (read $), but it's worth it.
In the meantime, one should ALWAYS verify disc burns for important stuff you're archiving--especially for CD-Rs where you're really not losing any time with such high burn/read speeds.
How do I backup data to CD or DVD and have the data encrypted?
By OM2 in forum Newbie / General discussionsReplies: 4Last Post: 6th Mar 2011, 17:53 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Errors in .VOB file burning as Data CD
By misterbean in forum Newbie / General discussionsReplies: 0Last Post: 8th Apr 2008, 01:31 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
