  1. In Nero i can burn a 780meg mpg-file in vcd-mode, but if i want chapters and using TCSV to create a bin-file i get problems.I cant get the bin/cue-file to fit the CD. Wich program is best to use and/or what settings to use? I've been trying with Fireburner but there the file can't fit properly on a 800meg-disc.
    What am i doing wrong or doesn't the rule about 80min =800megs if it is a bin/cue-file?
  2. "...get problems"
    What problems? Can you describe it in more detail?
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. When im trying to burn the cue/bin-file it doesn't fit.
  4. DETAILS
    For instance, what is the size of your BIN file? In MB.
    What is the reported size of the disc image when TSCV built it (it states at the end in terms of minec:frames?
    Are you making an XVCD?
    What are the exact error messages you are getting?
    Regards.
    Michael Tam
