I just got a new 2.4 Ghz Santa Rosa MacBook Pro (2 GB RAM). I wanted to compare SVCD (ffmpeg) encoding performance compared to my iMac G5 (2.0 Ghz, 1 GB RAM). The MB Pro with dual cores was only 5 minutes faster at encoding a 700 MB AVI to SVCD using the ffmpeg preset.
The dual cores obviously conferred no benefit whatsoever. If anything, the 5 minute difference was due to the 1 GB RAM difference.
Shouldn't the Intel Mac blow the doors off the iMac G5, especially with the dual cores?
Scallywag
You don't automatically get a speedup by going to multiple cores. The software has to be written to take advantage of the added resources. And not all tasks are easily subdivided in a way that allows for multiple cores to work on them. In this particular case, the particular encoder option you selected clearly doesn't make use of the extra core. Mpeg2enc has this option, so you may want to use it. In general, take a look at all the options for whatever encoder you are using, just to make sure you've selected all the performance-enhancing options that are available.
VOB files too fast/out of sync in Vegas Pro 10.
By rcavanah in forum Video ConversionReplies: 7Last Post: 10th Sep 2011, 21:14 -
should i go with the iMac or the Mac book pro for editing?
By funkdiva in forum MacReplies: 4Last Post: 12th Apr 2009, 12:02 -
Shoot MiniDV video off of an iMac and Mac Pro Laptop
By Rustyn242 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2009, 16:24 -
SVCD to DVD on MacBook Pro Intel 2.6 GHz
By brachium48 in forum MacReplies: 1Last Post: 6th Jul 2008, 08:48 -
New. I want a pro like Image Grabber II BUT with FAST FORWARDS Funiction
By mimo12 in forum Newbie / General discussionsReplies: 3Last Post: 15th Oct 2007, 12:54
