HI guys,
Does anyone know how you can calibrate the DVD lense as i am having problems with it, it appers to be accepting DVD's but after a short while it frezees the picture and thats it, no going further. I have opened up the unit as its out of warrenty and i have noticed that there is a screw on the laser unit board, BUT i dont want to mess about moving it without expert knowedge.
With thanks, Jon
These are commercial release DVD? not home cooked?
http://www.kiva.org/about -
I think you will find it's a lot more complicated than just turning a screw.
Here's one recent thread about 'laser realignment.' https://forum.videohelp.com/topic328888.html#1699340
And a short information article: http://www.howstuffworks.com/cd5.htm
The most likely mechanical cause is that the mechanism is worn out or the DVD laser is dying. But you can at least try cleaning the lens and seeing if the slide for the laser mechanism isn't binding. Most all calibration is done by the electronics on the drive. The coarse calibration is initially set at the factory with custom tools and you will never be able to duplicate that at home. But if you have nothing to lose and a little time to spend, give it a try.
One other point that may have not been mentioned in the other thread is that a DVD burning laser that has enough power to melt the aluminized layer in a DVD can also burn skin and the retinas of your eyes.
Be very careful playing around with that mechanism.
All these issues are likely to be unrelated to the laser. Let him trash his player to useless. Then see if the replacement also needs laser tuning. Fun to watch this play out.Originally Posted by redwudz
** end of post **
Product has been placed in the trash, ha, as its just as easy to get on from e-bay for the cost of repair....
Thanks however for all your help!
Jon
VHS to PC Capture Calibration ...
By JasonCA in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 22:41 -
Panasonic TC-P50S30 calibration
By dbanimal in forum DVB / IPTVReplies: 9Last Post: 7th Jun 2011, 17:39 -
Monitor calibration device suggestion?
By sdsumike619 in forum EditingReplies: 18Last Post: 4th Mar 2011, 06:33 -
Guide for Greyscale calibration
By Vrex in forum User guidesReplies: 0Last Post: 15th May 2008, 19:01 -
LG DVC9800 - test and service mode
By firebird-jpx in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 07:05
